Tire too small for 16x8 wheel?
Got a set of 214/55/16 tires real cheap. Thought they were 255's, but I messed up and now I'm stuck with them. Are they going to be too narrow to work on my 16x8 GTA wheels? Thx
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Tire too small for 16x8 wheel?
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
They should work, i believe. 215/2.54=~8.5" so should work.
1 Post
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
whoa that tire size is really pushing it though it may fit. 225 is already pretty much a flat tire wall with the rim. So it'll probably be a little streched out.
Car: 82 camaro SC
It should work, I used to have a set of 225/50R16's on the front(came with the wheels). 215/55R16 will be close to the same height, but 1 cm. narrower. I'm glad I won't be the one to mount it
Look at the pic in my sig. Those are 245/45R16's yours will be even shorter.
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
This is not a question wheather the diameter is OK, this is a question if a 215 should be mounted on a 8.0" wide wheel, and I say NO.
A 215 should not be put on a wheel wider than 7.0".
ok, I was just wondering in case i get a flat or something. I've got 255/55/16's all around now. I think it would look funny with 215's up front.
1992rs/ss
05-19-2020 07:02 PM
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
