4th gen, clunking from left front tire area
Car: 1986 Firebird
Engine: 2.8 V6
Question about a 4th gen, 94 Camaro (the fiance's car). Her dad thinks the clunk is a bad balljoint. I'm thinking it's a blown shock; it's got the original '94 shocks on it. I bounced the front end up and down a bit (when she wasn't looking, hah!), didn't hear a clunk at all. The clunk only comes up when she hits a bump. If it was a balljoint, wouldn't that clunk all the time, like when there's a slight dip in the highway, or when making a turn and the car leans?
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Hard to say. Balljoints can make all sorts of odd noises when they have play in them since they see such varying amounts of load on them. You are probably going to have to jack that corner of the car off the ground and give everything a good yank to see where the play is coming from. Could be as simple as a broken sway bar endlink. I would also give the hub assembly a thorough inspection as they are quite notorious for failing and having play in them on 4th gens.....
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Jack the car up in the air, or get that particular tire up anyway. Grab the tire at 12 o'clock and 6 o'clock (top and bottom) Now try to move the tire back and forth. If the tire has some play when doing this...Balljoint!...If not It most likely is the strut then.
P.S Check the tierod ends while you have it up for to much play. The tirods can make some awfull noises too. HTH
Keiran
Keiran
Engine: T.P.I L98.
Transmission: TH350
Originally posted by Matt87GTA
Gotta be careful with that test and really look at where the play is if there is any as play in the hub assembly will transmit through the wheel and tire and become evident when performing this type of test. But you should pretty much grab everything that you can and yank back and forth on it to check for play (ie. strut, tire, tie rod end(s), control arms, sway bar, etc.). Try checking everything with the suspension loaded and unloaded as well if necessary.
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
