Want to delete my power steering
In the continued modification of the engine bay, I want to get rid of my power steering too. I have heard of people using non - power steering assist boxes from an S-10 pickup I think it was. Does this sound right? Anybody have any information regarding this topic?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A manual box from a 4 cylinder S10 is a direct bolt-in. You may have to remove or modify the front sway bar for clearance. The S10 pitman arm can be used but the angle is slightly different. The third gen pitman arm is a better choice.
Using a manual box saves off a lot of weight. Driving on the street isn't that bad except sharp slow moving turns such as in a parking lot. There is also more turns required from stop to stop.
I don't recommend using a manual box if you have wide front tires.
Thanks, Stephen thats exactly what I needed to hear. The weight savings and the extra room are just what I need. I will keep the standard 245/45 tires and just fight it in the parking lots I guess. I don't really mind that much anyways because this car is definately not a daily driver. Only sees the roads on a sunny warm weekend day!
Car: 1998 Dodge Ram 1500 4X4 Quad Cab
Engine: 360 V8
Transmission: R47RE 4 spd auto
Axle/Gears: 9.25 rear/DANA 44 frt / 3.90 gears
Mike, are you interested in selling your p.s. gear box? If you are, if it is the high effort low ratio box I may be interested in it. The box I am looking for is 2 turns lock to lock. Thanks, Dave
hey Stephen if i do that swap withthe s-10 steering box would the tire i have now be good. i have 205/60/15's up front and 255/60/15s in the rear.
Dave, yes I would sell it if you are interested. I will not be back home until next Monday, so I won't know until then if it is the exact box you are in search of. When I check it out I will let you know.
colton_carlson
03-08-2019 12:21 PM
evilstuie
04-14-2016 08:52 PM
sailtexas186548
08-24-2015 10:11 PM
BlackphantomZ28
08-21-2015 07:12 PM
