The thingy ma-jig on my car has too much play I think???
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You know the thingy ma-jig, um
there is the stearing arm coming out of the stearing box, and on the other side is one just like it but its bolted to the frame. I think that thing has too much play, what is it called???
just a bushing thing??? it has a zerk fitting and I grees all the time.
Had to pull starter today and I noticed it had a bit of play, well more than a bit but not a bunch. But enough where I'm sure it either need tightned or replaced.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
it's called a Idler arm. If you've got play in it you should change it.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The whole arm needs changed??? not just a bushing or joint??? just asking, that a big hunk of metal, sue it not work just the busings,bearing or what ever holds it on.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just full of questions huh, dam, anyone know a place to get one for a good price, all Im seein is 40-60 bucks, [almost christmas, got 100 bucks and I need a starter first] I see idler arm busing kits but none listed for the thirdgen.
Car: blue 84 z28
Engine: mildly modified 350
It is a very simple swap...I would just swap the whole thing. I got mine from Performance Suspension Technology (PST) for about $35. Try to bolt it up in the same spot the old one was....I dont know if it makes a whole heck of a lot of difference....I just know you can adjust for bumpsteer by moving the thing up or down on its mounting area. Someone else might know if you need to get the frontend realigned afterwards. I did, only because I replaced all the frontend components at once. Good luck! By the way I dont remember any special tools being involved. Maybe just a pickle fork to separate the components.
Car: 84 Z28
Engine: 305 L69
Mark the position of the old one to the frame and put the new one in the same place. Moving the Idler up or down will change the toe of your alignment.
Linson
08-21-2015 02:12 PM
