1LE suspension???
Car: 89 camaro w/t-tops
Engine: lo3
super chevy magizine is modding a 85 camaro sport coupe from f41 to 1le right now.Part 2 of the series is out now, part 1 is reprinted in camaro performers.It looks like thy got the parts between the Chevy performance catalog,spohn, and stainless steel brakes.The change over looks to of cost them 2 grand in parts alone.
Car: too many ...
I get 1LE parts from rare junkyard / parting out 1LE/B4C finds. Only happens every once in a while ....
As far as the differences, heres info from the 'Tech Data' link on this website:
Then the 1LE performance package was installed consisting of:
Fog lamp delete
Aluminum driveshaft (JG1)
Performance exhaust system (N10) (dual catalytic converters)
Special deflected disc shocks
Aluminum spare wheel with smaller spare tire (N64)
Larger (11.86 inch) front rotors with Girlock or PBR Australian built HD front dual piston aluminum calipers
Special swinging fuel pickup in gas tank and special 18 gallon baffled fuel tank for fuel pickup down to .5 gallon reserve to prevent fuel starvation in hard cornering.
Some came with special 16x8 light alloy mesh wheels. (XWL)
Definately better than the stock stuff. But nowadays these parts are expensive if you buy new. It might not be the best bang for the buck. Try to find the rare junkyard deals. For the most part you might want to think about aftermarket suspension parts.
Fog lamp delete
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
go to www.1le.net
LT1Formula
10-08-2015 08:34 PM
1986, 1le, 2002, 3rd, 89, 97, camaro, camaros, difference, gen, information, option, parts, rare, suspension, suspention
