adjustable lower control arms-- just a gimick??
hey guys i have been doin some reading about suspensions lately because i have been interested in making my own lower control arms, panhard rod, subframe connectors, and possibly a torque arm. i am installing a higher stall converter and am anticipating traction problems. my problem is, i do not truly understand the purpose of adjustable lower control arms. we dont have upper control arms so to adjust the pinion angle you adjust the torque arm right? are adjustable lowers used to somehow preload the rear suspension via the torque arm? i was planning on boxing a set of stock LCAs and calling it good. if i lower the car in the future i would get a set of relocation brackets and an adjustable panhard rod to center the rearend, and if i needed to adjust pinion angle(which is prolly not needed for the 1-1.5 inch drop i would be looking for) i could use an adjustable torque arm. at this point i just dont see the need for adjustable lower control arms. i know very little about suspension geometery and have little experience with it, so i may be off base here, but i still dont see the need. can anyone fill me in???
1 Post
Car: 87 Formula
Engine: 327
I too dont see the real benefit to adjustable lca's.. The only thing i can see that it would change is the wheel base.. Maybe if the car is wrecked or tweaked somehow and the wheel base doesnt match from side to side, it could be adjusted by the lca's to make up the difference.
Thinking bout it a bit more.. since the rear moves in an arc as the car is lifted and lowered, the rear will also move forward and backward. So if you lower your car the rear end may no longer be centered in the wheel wells. Then you can adjust the lca's to center the rear again.
Well that's all I can think of.
Originally posted by 1MeanZ
so basically they are to center teh axle front to rear, just as an adjustable panhard rod centers it side to side? if that is teh case the only way to properly adjust them would be to put the car on an alignment rack.
If the car is accident free, just match rodend to rodend centerbolt lengths on the adjustable arms with a tape measure before you install them. Then when they are on the vehicle and you need to make furture adjustments, just count the rotations made to one side and match the other.
We ship our adjustable LCAs set at OEM length. They allow you to center the rear front to back. Many people use them to push the rear front or back to get tire clearance when stuffing in big tires. They also allow you to get a 4 wheel alignment.
Steve
Steve
Originally posted by drop-top IROC
So, what I'm hearing is that 90% of the people out there will not really have a need for an adjustable LCA?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
but if you want more than a poly/poly bushing, and you BUY them, you have to get adjustable
but as steve spohn stated, the come at stock length
although when it came to installing mine, it was really nice to have them adjustable that way i didn't ahve to wrestle with the rear at all, i just adjusted them slightly bolted them up, and adj. back to stock lenght
Car: 1990 Camaro RS
beacuse the non adj. don't come with rod ends
True. What is your main use for the car? Racing? Daliy driver? I just cant see putting rod ends on a daily driver. Too harsh and too much noise. And they wear out 5 times faster than poly/poly.
Im assuming you have the spohn lca's.....can you replace just the rod ends when they wear out?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
To get rod ends, you need a adj LCA. Rod ends will not bind. Yes the make noise. Yes they wear out. But performance wise, you can't get any better then a rod end compared to rubber or polly, which will both bind under hard cornering.
thanks for the info guys. i think for now i do 90% street driving. i think the non adjustable lower control arms will suit me best. i am either gonna box a set of stock lowers or make my own from scratch, to the stock length. i am also interested in lower control arm relocation brackets, but i am almost sure i can make my own. does anyone have any basic measurements they can toss out here? basically i just need 2 measurements. the vertical distance from the stock bolt hole to the lower bolt holes, and the horizontal distance from the stock hole to the lower holes. i am assuming the lower holes are a little farther forward to make up for the shorter distance between mounting positions due to the fact that the arm wont be flat anymore. i am a junior in mechanical engineering here at university of toledo OH, so if it helps i am proficient with auto cadd and ideas so dont be afraid to send drawings either.
1 Post
Engine: 305 TPI (LB9)
Transmission: WC T-5
You're on the right track, 1meanZ, I have the Spohn LCA brackets and the holes in the brackets follow the natural arc of the control arm when positioned lower. Your drawings look like they take that into account as well. For the $60 I spent on them, it wasn't worth my time trying to get someone to design and fabricate a pair for me plus, the Spohn LCA brackets are quality units and much cheaper than competitor's models.
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
adjustable arms?
all i know is i corrected a rear toe in problem with the adjustable arms..the adjustment was just .5 deg., but at least i could do it easily.
well my drawing sucks, i drew one in ideas but couldnt get it into a form to post here. you guys get the idea. i may just buy some but they are so simple if i just knew how far down to put the holes. i can do the math and figure out the arc and position the holes front to rear, all i really need is one measurement.
hey wdigitog, how the heck did you have rear toe in with a solid rear axle????
Car: 1990 Camaro RS
are you running lowering springs?
if you are making them, i would look at YOUR car, and found out how much you need to move the rear of the LCA down.
Car: 1990 Camaro RS
i would go look at your cars suspension, and make 1 set of holes at the point where the LCA is parallel to the ground. and then possible a set lower than that pair.
1 Post
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Re: adjustable arms?
Car: 1990 Camaro RS
how do you get toe in with a live rear axle?
or one side has a toe IN problem the other side has a toe OUT.
Car: '87 Camaro LT
Engine: 355 L98
Car: '94 Corvette
You brought up a point where adjustable LCA's are used in circle track racing. You can shorten one side, which will help the car turn in easier. *** Turn in ONE WAY mind you ***
Technically you could stager LCA's even on road courses if turns favor one direction.
Ron
Ron
ambainb
04-25-2016 09:21 PM
1992rs/ss
16
01-28-2016 09:58 PM
