Stiffer sway bars are in...questions
Just finished swapping a 34 mm bar up front and the 24 mm bar in the back. This replaced the 29 mm front and 19 mm rear bars the car came with. I also put new Federal-Mogul polyurethane end links on both bars, and WHAT A DIFFERENCE!! Before the swap, the car would roll away from turns very badly. Now, nothing moves at all as far as roll goes. So here's the questions....what else can I do to further improve the suspension?
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Eibach springs
Koni red Shocks/Struts
Energy Suspension polyurethane bushings
Sub fram connectors
and the list goes on and on.
Sub fram connectors
Tubular LCAs and panhard bar made a big difference on my WS6 GTA, which already had 36mm/24mm swaybars. Now the rear end is much more predictable and smooth. Corner drifts are about 5 times easier now.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
forget the wonderbar, it is nice little thing for prevention, and well worth the low price, but not exactly noticable for handling. get a strut tower brace if you want to stiffen the front end up.
Car: 1986 Firebird
Engine: 2.8 V6
If you're still running the original shocks/struts, changing them will make a HUGE difference. You could change them to the cheapest strut out there, and you'd probably still feel a difference!
darwinprice
17
10-11-2015 11:51 PM
