when should you start thinking about SFCs?
when should you start?
i just put in a 350 into a formerly 305 w/T-tops
i do plan on modding it, but not running it on the track (maybe just once to see what it can do)
should the SFCs be the first thing i get or should i do some other stuff first.
car is sound, no probs just stock.
ideas??
biker
ideas??
biker
Engine: 5.7
All thirdgens could use subframes especially T-Tops & convertibles. Mine really stiffened up my ride and reduced body flex when going over bumps and acceleration.
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If you have the cash, get em ASAP. SFC's improve the both the ride and handling on these cars. Any squeaks and rattles from the body will be greatly reduced if not completely gone. SFC's when installed correctly also serve as jack points. (Being able to lift the car from almost any point along its side is a definite plus IMO)
to me SFCs ar aboutthe firstthing you should do, but most people do the engien first. i'd either buy or make a set ,not hard to make if you can weld, or know soemone that can.
i know they are good
my big fear is that picture of a camaro on irocone.com (i think) that is jacked up and the car has a wheel off the ground that is not suposed to be off the ground because it chasis was twisted so bad. I just don't want my car to do the chuck berry "twist and shout"
biker
biker
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
As soon as Spohn starts making them again.
I know, I know .....
But they are next on my list!
Ed
Ed
Ed
Location: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
When is Spohn gonna be back to maiking them?
Q: "When sould you start thinking about SFCs?"
A: The moment you find out they are available for your car.
I hadn't heard anything about SFCs unitil I saw posts about them on ThirdGen.org. I had already been thinking up methods to reinforce the chassis on my 90 RS 'vert. I had them installed in less than a month. Lon
1 Post
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
The difference in handeling you get from subframes are unbeleiveable. I had no idea they would make so much of a difference. Do your self a favor and install some as soon as you can! If you have any kind of metal fabrication skills (and tools), they are very easy to make.
post a pic of SFC's?
Can anyone post a pic of these subframe connectors installed?
I am a bit confused as to what they are and how they connect that makes everyone rave about them.
Chip
Chip
here is a pick of weild on ones
from what i understand they are really easy to install
what they do is stiffen the car up to improve handling
when your car goes up a drive way Bump at an angle don't you get a creak coming from the frame, that is the frame bending. this happens alot on T-top cars also t-top cars tend to bend when they have a high end (hp/tourqe) 350 in them because of the touqe. picture a icetray you get from your fridge. you can bend it side to side and in half right? that is what your car is doing. SFCs help to stop that. bolt on ones are ok, weild ons are better. bolt ons just have a normal bolt attaching the SFC to the body of the car, they work but after awhile the stress of the car on the bolt will cause it to wear on both sides of the SFC causing it to be loose. weild on ones weild on like 6"-8" inches of steel at each end to the car, better than that 1" bolt right?
there is a pic of a car on irocone.com i think of a car on a jack stand that you can see that the frame is twisted.
biker
biker
Originally posted by BikertrashDude
....there is a pic of a car on irocone.com i think of a car on a jack stand that you can see that the frame is twisted....
http://www.iroczone.com/newindex.htm
the frame of the car is not twisted. the frame is so tight because of the SFCs that this happened with only one jack on.
biker
wow... that is impressive
I just found the BMR sight as well and they have a few good pics up and it all makes sense now, that is pretty impressive though the way it stiffens the body up like that! I've gotta have some now!
Thanks biker!
Thanks biker!
I don't understand your big fear, Biker. That picture shows exactly what a good sports car should do. With a stiff frame and firm suspension, there is no way to jack up one side of the car without lifting two wheels off the ground. That's a good thing, nothing to fear. Well, I can understand having a fear of getting under that car, but that's why you use two jackstands (and not to lift the entire car off the ground like the second pic shows. That one should be using 4 jackstands, but I'm assuming it was done mearly as a show and tell. You know, see what I can do with my car.) I've seen vettes and one porsche do the same thing. My 88 Trans Am does that with just a strut tower brace installed, and it didn't do it before the brace was installed.
No i have no fear, My first question was should i get them now or wait....
.....i was just showing those pics because someone asked what are they for (SFCs) and what they do. I'm sure those pics are just for show.
biker
biker
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
yea the pics you showed are GOOD examples of what SFC do for your car.
the frame is now very rigid that jacking at any point along the flank will race the entire side.
try doing that on a non SFC car. the twisting is horrible to watch (and listen to!)
I just put my homemade ones in, I didn't think I would notice much difference, but even the ride quality has improved. my car used to be a rattle box, now i hardly hear a squeek.
Body roll has reduced.
The next thirdgen I buy will get SFC's as it's first mod
my grandfather has a welder, so i am going to buy weld in ones, but how do i jack to the car up to get under there and weld them?
do u think a muffler place would weld in some sfc's?
92camaroJoe
08-13-2015 06:07 AM
