Koni Rears Just installed have some ??
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I recently replaced my KYB's with a set of Koni Reds. I put them on the 1st setting in fear that would be too much. But it seems a little more softer then the KYB's were. also it seems I spin the tires forever with the koni's compared to the KYB's any suggs? What does everyone else have there settings on? Thanks
So why don't you bump up the firmness?? Maybe they're being too cushiony and not planting the rear, even though that should be the job of the springs, the shocks only dampen. I think you've probably got something else goin on... is the car lowered?
1 Post
Car: Formula
Engine: 6.0 LSX
Car is not lowered. I do have relocation brackets , LCA's BMR TA set at -2* i had like 0 wheel spin with teh KYB's and a crap load with the Koni. I'm just asking if adjusting them willl help Thanks
Stiffening them up helps a ton. I have mine on full hard and can't spin the wheels at all. Springs help with the launch to a degree, but shocks make a much bigger difference.
hectre13
12-11-2023 08:14 AM
I'llrocya
02-02-2016 11:43 PM
hectre13
08-26-2015 08:17 AM
