Jegster "Frame Ties" subframe connectors
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Installed these yesterday. Took about 2.5 hours once I got the car up on ramps. I took pictures during the install. See my website for the pics and additional installation commentary.
Overall, they were easy to install. No complaints! Haven't had a chance to really test them out yet.
Rob
Rob
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Jegsters SFC
Thanks for your post. I am returning my Chassis Engineering SFC's to get the Jegsters. I think a bolt in is a good start. The benefits can be felt immediately and the welding can be done when the right deal if found. My quotes were like $200.00 and the part is only $85. I cannot justify that so I think a bolt in is the way to go. Great idea on the ramp by the way!
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
let me know how u like them caus ei will be gettin some when i put in my 350. also do they go right into the floor pans? did u have to rip up your carpet to get the bolt in??
They bolted right in with only minor "problems" that were easily solved. The "wing" on the pax side didn't quite fit up against the floor, but a longer bolt was used to pull it up tight, then the supplied hardware was installed and the longer bolt removed & replaced with the supplied parts. You do have to pull up the carpet, but that's easy. I forgot to mention that on my website... duh. I'll have to fix that. All you do is remove a couple of screws on the kick panel, remove around a half-dozen screws on the threshold strip, and pull off those pieces. The carpet then lifts up. I put a piece of 2x4 under the carpet to hold it up away from the drill bit when it came up thru the floor. Then you just put a washer on the bolt, drop the bolt into the hole(s) you drilled, and then put a lock washer and nut on the bolt and snug everything up. The put the carpet back down, replace the threshold and kick panel, and it's done.
Rob
Rob
Car: 89 Formula
Engine: Carbed 5.7
that sounds easy enough. do u feel big bumps in you carpet from the bolts or are they out of the way mostly? thanls
Rob
I'd weld them up as soon as you get the chance. I've heard plenty of stories of elongated holes from people who just went the bolt route. If you buy bolt-ins, have them welded in as well.
Rob
88 Drop top mentions the Alston SFC. How about giving us some photos or supplier information on those. I went out and did a web search and came up empty handed.
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I too have the Alston's in my car(welded).Now after seeig this post about the Jegsters I too am thinking of putting a set in my car along with the Alston's.Anyone have a reason why this would be a bad idea..besides excess weight,which for the purpose of strength I don't mind.I also have a S&W 8 pt cage in the car so this may just be overkill,but any help is good in our flexi flyers..right?Two has to be better (stronger) than one?!?!
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
