Car pulls to right
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
Car pulls to right
I hit a pothole a few months ago and had the front sway bar, bushings, and end links replaced and 6 times had the front end aligened and now rotated the tires and the bastard still has a slight pull to the right when I let go of the wheel. Net is the brakes to get checked, but what the hell else could be wrong? This is a '91 Firebird Formula, Thanks for any help! Andy
Car: 82 camaro SC
What are the most current alignment specs? I usually set up third-gens with a little less caster on the left to compensate for the crown of the road causing a slight right pull. Double check the tire pressure and then swap the front tires left-right right-left and see if it still pulls to the right--that will eliminate a tire causing the problem. Keep in mind that an alignment can be 'within specs' and still pull if not done correctly. If you want to try another alignment I (we) can post some good specs to try.
Ghettobird52
07-05-2024 11:18 PM
