Independant Rear Suspension
#51
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Originally posted by okfoz
KEWL! I would like to know all the specifics, but I imagine we will get to them like:
did he move the gas tank?
Can you still remove the gas tank?
the little things...
John
John
#52
Car: 94 Corvette
Engine: LT-1
Hello all. Here are the pics that I promised. The deal w/ the torque arm is that the Vette rear carrier has the mount on the opposite side as the F-Body. He just retrofitted a Random Technologies arm in there. I can get more specific pics as questions arise. These give the general idea though.
#53
Car: 94 Corvette
Engine: LT-1
Sorry, but I can only post 1 at a time. Anyone know how to fix that?
#56
Car: 94 Corvette
Engine: LT-1
It was quite a job to get it in there. The shop that did the bulk of the work had never done one before, and therefore it wa an exercise in try thi here and that there until it was perfect. Just so you all are aware the COMPLETE this conversion was somewhere around $5000.00 (not a typo). My brother has siad that it was well worth it though. The shock factor alone is quite impressive. Let me know if anyone has any questions about tis conversion.
#58
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Gee, I like the idea of what was done, but I am not crazy about the routing of the exhaust. I was hoping to keep it up high, (above the suspension.) it looks like You would loose some ground clearance. On most bumps it looks like it would be ok, but I wonder how much lower it is compared to the stock Pig...
John
John
#59
Car: 94 Corvette
Engine: LT-1
Actually the exhaust has only drug once or twice. The diff is tucked up in the hole quite well, as you can see by it's proximity to the fuel tank. The exhaust is up further than the stock exhaust on the C4 Vette. It's tough to believe but his IROC is lowered about 3-3.5 inches. The only thing that drags on occasion according to my Bro is the air deflector and every now and then, the cross member that the touque arm bolts to (only on big speed bumps). I think that the stock cat in my 87 Trash Can was lower than any part of his exhaust system. A good performance exhaust shop can do some great things with exhaust tubing.
#61
So what shop did that??? like the last guy said, if you dont want to post email it to L3323P@yahoo.com
THANKS
THANKS
#62
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
=D
Hey Guys,
I just bought a dana 44 corvette rearend with everything on it. I am going to do my best to get in sometime late summer or fall.
I'll try to keep you posted.
#63
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Re: =D
Originally posted by Trux
Hey Guys,
Hey Guys,
good luck and keep us posted.
#64
Transmission: t-56
thanks
I need all the luck I can get.
A hot rod shop near me has offered me some help though.
I need to get aq digital cam. Was going to get one anyways, finally need a got a reason to get one.
#66
Thats cool! But what would really be nice is some during the mod pics, like pics of what had to be reworked under the car, the upper mount looks pretty simple, but how front mounts for the stut bars would be fabbed up baffles me. Also what is stock track for the C4 rear, if it has to be modded just to get the track right this really would be a pain, also how is the ride height with the stock 'Vette spring, and how would you raise/lower the height to get the car to sit right. Well, guess its time to peek under my friends 'Vette.
#67
Transmission: t-56
Hey
I have not even start to work on it yet. Working too much lately. Hopely I will have a digital camera to get some picks in another week or so. I have been looking around for more parts to it. I got some crosss drilled and sloted rotors for it and new calipers with ceramic pads. I can't find any e-brake cables for it though. I am going to see if I can get the cables from another car with disc e-bakes to work.
#68
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
just to add some info. i was surfing the web last year sometime and ran up on a third gen independant rear. the only weird thing about it was the brakes were in the center to at the hubs. but it was like 2000 so i said nevermind. my 2 cents
Nick
Nick
#69
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
That sounds like a Jaguar rear suspension. They used it on the XKE, XJS and older XJ6s. The brakes were inboard and they had a hard time colling them. They also run 4 shocks on the rear suspension. It actaully is a good design and is pretty compact.
#70
1 Post
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I came across 3 Jaguar rear end assemblies, all complete with inboard dual pin disc brake setups/ and stock coilovers- A little rusty but $450 each. That would be nice to tinker with if my car were not finished. Anyone interested call S&W Towing in Hawthrone, Calif. They have them sitting in the back of the lot collecting dust.
#71
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
Air Ride (i think) makes a kit for air bags suspension on a chevy s10 that convert the rear into IRS. The thing that made it interesting was that no cutting or modification to the rear, it was all bolt on.
#74
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Originally posted by TPl383
not mine Just pic's I saved.
http://s89724942.onlinehome.us/image...IRS%20rearend/
#75
1 Post
Car: 92 Z28
Engine: Boosted LSX
I agree. I could do bettr overhead with inspection mirror in a plane wing...lol.
id like to do this conversion if I could find a cheap complete setup for my vert.
but I think the ford 9inch will hold upto the power levelas Im shooting for anyways..
#76
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Originally posted by REZN8R
A note on 1st gen cars. Correct me if I'm wrong, but I think the 1st & 2nd gen F-body's had a body and a frame. The 3rd & 4th gen have a unibody. Therefore it would be easier to put a IRS setup on a 1st or 2nd gen. Right?
#77
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Originally posted by soulbounder
I know Comp. Engr. used to make rear frame rails that would extend off of our existing rails simulating a full frame in the rear. You could weld a crossmember between them to give the IRS a mounting place.
Here's a pic for those who need something visual.
too bad the diff wasn't a little longer
one way mazda dealt with the crossmember mounting was to have a long snout on the diff like such
didn't cause problems with mounting of the gas tank and such
maybe though there is a way to adapt something to mount the cross member forward a little more though and have it reach back to the diff.... though don't try it unless you know being I'm just assuming and this isn't something I knwo too well just trying to throw an idea out there if nothing elese
#78
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Originally posted by AFrikinGoodTime
Sorry to burst your bubble but this example is not BUMPSTEER, It is simply LOSS OF TRACTION. Panhard bars do not create bump steer either. In their range of motion they only cause tranfer of weight.
Bumpsteer is only caused by a bump in the road changing the angle of attack of a front wheel by shorting or lenghtening the geomety of the tierod causing the tire to change the path intended by the steering wheel.The car is steered differently than intended by the dip or bump in the road and should not be interpeted that by hitting a bump with a tire and skipping off is bumpsteer, merely loss of traction.
The reason why IRS works better on uneven surfaces is beause the bump is only absorbed by one rear tire causing only one tire to lose traction. On a solid axle, both tires are affected by the bump. Solid axles work better on smooth surfaces than IRS because of less deflection of working components ( less moving parts or pivot points) and camber can not be flexed or changed by cornering forces. That is why we don't need a rear spreader bar (a.k.a. strut brace, etc.)
my question is with turning on smooth surface I'm sure the camber change (relative to ground) would change on a live axle car being that the axle prolly would lean a little as well.
with an IRS car as the wheel is pushed up it will gain a little more camber to help keep it level on the outside wheel but the inside wheel might even gain a little possitive camber to help keep it flat
again might be wrong and if so please correct me and let me know
#79
Car: 2005 BMW 545i
Engine: 4.4L N62B44
THat would help on our balance by getting more weight in the rear.
ON A SIDE NOTE:, interesting fact, the Vette was not the original car to have a front engine, rear trans from GM. Back in the 60's there was a little Pontiac, that was built on the same platform I think as the Skylark (cant remember the name). It used that setup and the rear suspension of the Corvair...
John
John
don't remember the details but cool interesting design
#81
Car: 92 25th Anniversary Z28/RS
Engine: 305 TBI.... (for now)
Re: Independant Rear Suspension
ok so c4 irs install has been confirmed, what about C5? C6?
C5 wrecks are fairly reasonable at 5-10k for something with salvageable enginer/trans/suspension and all the other bits.
anyone know if the trans/IRS is drastically improved in the c6 compared to c5? or is the c6 just a slightly improved c5, as i head back at its debut
#82
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
the c5 and c6 use a rear mounted trans and a torque tube, so unless you swap everything, i think it would be a difficult project. the c4's still had the trans on the engine which is why its better suited for this swap.
I've toyed with the idea of doing this with a future car, but there is a lot more involved that just making the rear fit, like tuning the suspension.
bjpotter
01-22-2019 12:27 PM
