Removing the steering wheel from a GTA
Old 05-22-2002, 09:27 PM
The Dirty Bird!'s Avatar
Car: 89 GTA
Hey guys, I have to fix the problem with my steering wheel wiggling up and down and all around.
I read the Haynes manual on this, but since the GTA steering wheels came with the stereo controls built onto the steering wheel, so it has no info on it.
Any ideas as to what additional steps I should take?
Old 05-22-2002, 10:23 PM
lasersi's Avatar
The center of the wheel containing the controls is Velcro in place and is connected by two wire connectors after you have pulled the center section out. Under the controls is one large nut that needs to be removed. Once you remove the nut brace your knees behind the wheel on opposite sides and wiggle the wheel until it comes off.
Good luck!
Old 05-23-2002, 12:04 AM
Car: 89 GTA
Great info, thanks!
Should I have to disconnect the battery at all before I start unplugging the wires?
Old 05-23-2002, 12:13 AM
lasersi's Avatar
It is always a good idea, however this is only connectors so it probably won't matter.
Old 05-23-2002, 12:34 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Like he said, the buttons are on with velcro - just pull it off. The connector on the bottom and on the right just pull off. The connector at the top left needs to be turned a little and then pull out (spring inside).
Voila!
I used a wheel puller to get mine off. It was on there good!
-Schultzy
Old 05-23-2002, 12:51 AM
Car: 89 GTA
OMG thank you! :hail:
That doesn't look so bad...assuming you have patience...and a 3 day weekend!
File -> Print...
Thanks again!
Old 05-23-2002, 11:39 AM
Car: 1989 GTA
Your welcome but it really will only take 15 - 20 minutes. I just took pics at each step in case someone might need it.
-Schultzy
Old 05-23-2002, 11:44 AM
TGO - 10 Year Member
Steve89GTA's Avatar
Do you think it will actually come out with the knee trick? Even if the wheel has been on there since 1989? I'll have to give this a try...
Thanks for the info and awesome pics!!!
Old 05-23-2002, 11:46 AM
Steve89GTA's Avatar
Speaking of wheels. Would you guys get the original one redone in leather (mine is shreaded) or would you just stick an aftermarket GRANT type wheel on there. I'm contemplating it. I like the look of the stock wheel (even though I've changed the stock deck to a Pioneer large face wich came with a steering wheel mounted remote). I like the look of the stock wheel though (lighted buttons are trick..lol.) I wonder how much it would cost to rewrap a leather wheel.
Anyone have any info?
Thanks in advance.
Old 05-23-2002, 02:03 PM
Car: 89 GTA
Thanks in advance.
I'd get it redone in leather, IMO it looks better.
But everyone has different tastes.
Old 05-23-2002, 02:39 PM
Car: 1989 GTA
I went with the Grant...
-Schultzy
Old 05-23-2002, 02:41 PM
Steve89GTA's Avatar
How much are the Grant signature wheels. I'm guessing they're just as much as the MOMO's correct? Looks great man!
Old 05-23-2002, 11:35 PM
Car: 1989 GTA
Thanks!
Most of the Grant Signature wheels are $160 - $180.
Frozer!!!
01-19-2024 04:55 PM
backtothe80s
09-05-2015 12:39 AM
Keiffer76
Car Audio
08-09-2015 11:37 PM
mustangman65_79
08-09-2015 03:00 AM
johanlindgren
Wheels and Tires
08-06-2015 03:32 PM
Quick Reply: Removing the steering wheel from a GTA
