Falken Azenis 255/50ZR-16's on an IROC
Guys,
I have an 88 IROC with the 16" wheels. The stock size tire is 245/50-R16 The nearest size Azenis tire is 255/50ZR-16
Will this tire fit without banging on the car? Would I be more likely to see problems on the inside of the tire or the outside?
Our autocross club is going to do a group buy and I want to make sure that I will not cause problems for myself if I get them.
Any help would be appreciated
LIL QIK -
Do you have any suspension mods on your car or is it all stock? I am drooling over these tires and want to be 100% sure that this will work OK.
Car: 2004 GTO
I have 255/50/16 BFG ZR tires on my Formula. No problems, other than a little rubbing on the front inner fenderwell when turning at full lock at parking lot speeds.
The car that I had them on was a lowered RS. It had the Jegster Torque arm, edelbrock trailing arms, and the Lakewood adjustable panhard rod. I really don't see you having any problems runnnig that size tire. I've transfered all that stuff to my z28 and now running 315/35-17s' and not having any problems. Ofcourse I've massaged the inner fender well with a sledge since I've gone to the big tires.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have Falken 255-50ZR16's on the rear of my 92 RS,and 245-50ZR16's on the front.Both on factory 16x8" wheels.Nothing rubs.
-Rich-
-Rich-
mustangman65_79
08-11-2015 03:17 PM
