1982 - 1992 Chevy Camaro T-Top Hatch Drip Edge Weatherstrip Seal RUBBER PAIR
Former Sponsor
Click here to order and for current pricing.
THEY'RE FINALLY HERE!!!!!!!
This T-Top weatherstrip seal PAIR are a new, aftermarket parts. They mount on the edges of the T-Tops and helps to deflect the rain onto the side of your door glass . Most of the original seals are usually torn at the edges or missing. If your old seasl are leaking water or causing wind noise when the windows are up, this are the seals you need.
Features:
Comes as a PAIR
Fits both the LH (Driver) & RH (Passenger) Sides
Replaces dealer part number: 10198352, 10198353
Molded exactly like the original on your car
Smooth soft fine grain rubber
Direct Replacement for either the soft rubber or hard plastic style
Also known as sealing strips
Buyer will need to secure with weatherstrip adhesive
Note: There were two types of drip edges produced. One was rubber and the other is hard plastic. This PAIR is the rubber style.
NOTE: Some 82-92 Camaros and Firebirds were converted to t-top cars after they left the factory by a company called Cars and Concepts (C&C). These aftermarket t-tops are not interchangeable with the stock ones and require different weatherstripping. To determine which top style you have, remove one of the tops and measure the side the tucks into the center support section of the roof. Factory, or Fisher, tops will be 30 1/4" while the C&C tops will only be 28" long. 1A Auto does NOT stock or carry the replacement C&C weatherstripping.
If your weatherstripping is causing leaks allowing damaging rain in, then this seal is for you. Why not replace your old, hardened, rotted seal with this new, ready to install weatherstrip.
Features:
Comes as a PAIR
2011 Norwood Gathering
ThirdGen Camaro Rep
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: 1982 - 1992 Chevy Camaro T-Top Hatch Drip Edge Weatherstrip Seal RUBBER PAIR
Ordered mine
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
Glad these are finally available! Mine need replacing real bad. Both sides have peeled away at the ends and the sagging causes them to hit into the window, when closing the door. That usually causes the door not to engage fully when using moderate force to close the door. I'd like to be able to close my door without practically having to slam it for a change. This will get me one step closer to that.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Just ordered mine, thanks!
Car: 1991 Camaro RS
Engine: 305 TBI
Axle/Gears: stock
I WILL be getting a complete set, eventually, my car spent most of it's life in CA so most of the rubber pieces have dried out. All I need now,Tony, are the parts inside the doors that the windows rest against at the front just below the mirror.
Former Sponsor
HI Jay,
As of right now we currently do not have that seal available to us.
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
1982, 19821992, 1985, 1986, camaro, chevy, door, interchangeable, iroc, left, replace, side, tops, ttop, weatherstrip, weatherstripping, weatherstrips, windows
