Leaking Steering box
Hey guys. I have a 91 camaro with the fast ratio box that is leaking. What would be a good replacement for this? Should i just have the original rebuilt? I have read that some people had bad luck with reman units, and I have never rebuilt one. Any advice is appreciated.
Thanks.
Thanks.
1 Post
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: Leaking Steering box
Here is some info on rebuilding. It is cheaper, but time consuming. You also get to see the works for wear.
actual post
from 'how-tos'
I have a kit being shipped, think I'll be able to do it next week. Kit was 27 bucks or so. Hope it is the correct kit. edit:this kit does NOT come as pictured, it is only pitman shaft seal kit, 2 metal washers, 2 outside gaskets, one big oring, one snap ringkit I bought
actual post
from 'how-tos'
