New best times at San Antonio Raceway
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: New best times at San Antonio Raceway
Hi Vincent. Excellent MPH! Traction should lower E.T. a good bit. Congrats!
What was the DA at the track?
Bill
Bill
Et timing? 1/8 et matches the 1/4 et when using the low end of the conversion factors. Typically i see 1.54-1.57 used as a multiplier to the 1/8 mile et. Faster cars with very strong top ends seem to use 1.54-1.55 while slower cars with less mph gain from 1/8-1/4 use 1.56-1.57.
Your car is showing it has strong top end pull. Just need to get the 60' down into the 1.6 range and you'll be mid 11's easily, and a 1.5 should be low 11's at 119 mph.
Nice times. Like Orr said that back half is super strong. You just need to figure out how to launch the car. I have the same problem with my Skylark. I took it to Fontana yesterday for one pass. I need to sort out the launch. Mine is car #3000.
Car: 87 Iroc 5.7,67 SS Camaro,90 Formula
Engine: 355 AFR Superram LPE 219
Transmission: 700r4 3000 stall 4spd 5 spd
It looks like if you can get the 60 foot down to 1.6's or so thats a low 11 sec or better car. Maybe get more mph if there are bugs to be worked out. I'm jealous.
327_TPI_77_Maro
02-18-2016 03:34 PM
hotrodjames
Southern California Area
02-15-2016 04:43 PM
