SoCal TPI Dyno Day Saturday December 15th
We finally have enough cars together to have another dyno day, along with our final meeting of 2012.
http://socaltpi.org/forum/viewtopic.php?f=3&t=104
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Re: SoCal TPI Dyno Day Saturday December 15th
Kevin - is there still space available to dyno one of my cars? What's the $$?
Car: 89 GTA
Axle/Gears: 4.10
Sorry Kevin - It's Dave I'll try to get my TTA prep'd for Saturday!
Sorry Dave.
Lon, you're approved.
Spectators are welcome at the dyno. Please come and learn how to dyno a car, and how we get the power we do out of our TPI engines.
Also, if you cant make it during the day but want to come to the meeting, watch this space and I will post when we're leaving the dyno and heading to the restaurant.
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
I can make it to the dinner part, as long as it's after 2 PM.
1 Post
Car: 1988 Pontiac trans am
yes ! , i'm so0o0o going to this one . i'll bring the camera to get some video . People don't believe that you guys are putting together 400 HP engines that pass the emissions test .
Car: 84 Camaro Z28
Engine: 355 Carb
If it rains tomorrow I would pass by to check the dyno runs
Car: 89 GTA
Axle/Gears: 4.10
I'm going to try to make it early in the AM, hoping I can get a couple of pulls and get back to San Diego by noon to work on my other car!
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Always miss this good stuff having to work every weekend.
Hopefully in Jan/Feb I can get a day off to do something and meet you guys
Missing a day this mo wouldnt be a good idea where I work
Soon
Thats cheap for dyno time!!
Soon
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Getting tuned @ MD with Kevin91Z and crew gets you service, value and fun that can't be beat.
Wish I could be there!
Bill
Car: 89 GTA
Axle/Gears: 4.10
Waiting for people to upload the dyno videos I was having too much fun to even take a picture of my car on the dyno!
1 Post
@ goose . what were your HP/Torque results on your pulls ?
1 Post
halfway done with the editing . I need to know gooseman's results for each of his runs . that's all i need .
1 Post
Maxing out their fuel pumps. Not sure if good or bad? Sign of progress ?
Lowest numbers of the day were 270-ish HP and 300 torque. ( correct me if
I'm wrong) .
I really hope it's not the fuel pump. It's not even a year old. I changed out the fuel filter and it seems it gave my car some of its ***** back. Time for another Dyno.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
BTW did we mention the TTA we had on the dyno
INSANE numbers.....518/570
Congrats Dave!
Congrats Dave!
Sure. It could be clogged so bad that all a car will do is idle. So it just depends on how badly clogged it was. It will affect the flow rate or how many gallons per minute it will alow to flow. It can still create pressure if there is hardly any flow against a dead head.
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
I just hooked my dynotune digital nitrous guage to read my fuel pressure in-car.. I am seeing pressure drop with my turbo setup. It's a boost referenced fuel pressure regulator also.. 55psi idle, 62at 0 boost, 65psi at boost/low rpm and it drops down to 40-45psi in upper rpm...damn.. ill try a new filter and then drop in an extra walbro if I need to. It's nice data to see! Also hooked up my method kit and made my.boost guage illuminate when the method kit is powered on.. no need to have boost guage illuminated until boost is being read. Awesome...
Nice numbers guys!!
Car: 89 GTA
Axle/Gears: 4.10
Yeah, stock block with 70,000 miles on it (very hard miles). My last run my boost was around ~22-24psi. That's about all my 6152 turbo can do with the ported heads letting it free flow into the engine.
Well done indeed gentlemen!
Question, are these fueling issues a result of sucking the fuel rails dry requiring more pump and/or larger diameter fuel line or simply not enough injector causing them to go static?
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
Congrats to everyone dyno-ing for keeping us inspired with their projects, and those with the big numbers too of course!
Keep on updating on your progress! & happy holidays.
#42
Excellent job Luis....
Thank You.
Thank You.
#44
1 Post
Thanks for the compliments guys,
Its my first time using Sony Vegas
editing software. Hopefully next
time I can use the full potential
of the program.
of the program.
#45
Great video.
But my car did make at least 347 rwhp that day. ;-)
#46
1 Post
sorry , i got the HP numbers wrong . I finished this video at 4 AM this morning , crashed then uploaded the video around 7 Am . In hindsight i should never render videos at those hours with little sleep.
#47
Don't worry man. I'm glad you put that video together. I want to see more in the future.
#50
Car: 68,87,99 maros, 07 tbss
Engine: TPI,LS2,LSA,L92
Transmission: T56,T56,T56, 4L80E
Axle/Gears: 12bolts and 14 bolt lol
Great work on the video. Not like it matters much but my Iroc is an 87, not an 88.
