Latest TPI project
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Latest TPI project
First time for doing a First Intake.
Re: Latest TPI project
It has the new Procomp heads, XFI 268 Comp cam and my custom headers
(1 3/4" primaries) kind of low on compression (9.7) but it is a short block built by someone else.
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
Looks GOOD!
First Intakes & the standard are NOT the same lol!
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Do you figure the tb cable bracket would work for an early tpi style (88') ?
Does the intake sit higher than stock (would it fit under a stb) ?
It looks killer and those 1 3/4" runners are wicked!
No the TB brkt. is their own. (spec.)
It is a little taller, I don't think it would clear.
Any plans to put it on the dyno yet? I would love to see the numbers on that. Yes it will be going on the dyno.
Fast355
12-02-2016 06:33 PM
ambainb
04-25-2016 09:21 PM
Sanjay
08-12-2015 03:41 PM
1992 Trans Am
08-09-2015 04:32 PM
