FS: electric bike
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
FS: electric bike
Looking to sell my Currie tech eZip Trailz electric bike. Bought it a couple months ago but realized i dont care much to ride it. ( i build cars) for the couple times i rode it it is pretty fun and fast.
retails for over $600 new ill let it go for $350.
heres some info about the bike from there site:
The Trailz is getting more people back on a bicycle. It's easy to use, a sheer pleasure to ride and an amazing value to boot. Powered by Currie's Electro-Drive® system, the rider gets to choose from power on demand or power assist functions.
The Trailz is the perfect bike for many uses from recreation to transportation. Its powerful Currie Electro-Drive® system has 450 watts of power that provides plenty of torque to level hills and is powered by a sealed lead acid (SLA) battery pack that can easily be removed for charging or swapping. It can travel 15-22 miles with normal pedaling or about 10-15 miles with no pedaling at all at speeds of 15+ mph. You can easily double that range by adding an optional second battery pack
MOTOR 450W of Power from a DC Brushed Earth Magnet Motor
BATTERY EV Rated SLA Type, Rear Rack Mounted, 24V / 10Ah Pack, (2) 12V / 10Ah Valve Regulated, Rechargeable
CHARGE SYSTEM UL Listed Currie Smart Charger with LED Status Display
CONTROLLER Exclusive Currie Electro-Drive (R) 24 Volt Fully Potted with Power Gauge Function
TOP SPEED 15 mph / 24 km/h (Rider Weight, Rider Input and Terrain Contingent)
RANGE Up to 15 - 22 Miles / 24 - 35 km with Normal Pedaling (Rider Weight, Rider Input and Terrain Contingent). Easily Add an Optional Second Battery Pack to Double the Range
DRIVE Patented Currie Electro-Drive (R) System, Shimano Rear Derailleur, SRAM Grip Shift, Shimano 7 Speed Freewheel
BRAKES Alloy Linear Pull with Alloy Brake Inhibit Lever
WHEELS Alloy 26" Rims
TIRES Currie Comfort Tires 26" x 2.0"
HANDLEBAR / STEM Mid-Rise Bar and Stem
FORKS Suspension with Fender Eyelets
USER CONTROLS Power On/Off Switch, Easy Access Charger Port in Removable Battery Pack, Twist Throttle with PAS+TAG Function and Battery Gauge
SADDLE Comfort Design, Q/R Alloy Post
FRAME Exclusive Currie Hi-Ten Steel, Bottle Bosses, Fender and Rack Mounts
CRANKS AND PEDALS Alloy 44T Crankset, Double Chainguard, Resin Dual Sided Pedals
NET WEIGHT Diamond Frame 68 lbs / 31 kg Low Step Frame 66 lbs / 30 kg
RIDER AGE & WEIGHT LIMIT Young Adult to Adult / Do Not Exceed 240 lbs / 109 kg
SIZES Diamond Frame, Low Step
PAS/TAG ( Twist and Go or Pedal Assist ) Electric Facts
Allows users to select between two modes.
1. PAS Mode: Pedaling w/o throttle gives 50% of available power assist, conserving the battery. Pedaling while Activating Throttle allows user to go from 50% to full power or anywhere in between.
2. TAG Mode:: No pedaling required, just throttle from 0% to 100% power
Mode
TAG/PAS System
The Advantage: Rider can select between two power modes.
The Benefit: TAG allows you to power the bike
without pedaling at all. PAS mode without throttle stretches range and economizes battery usage.
Electro-Drive ®
Patented Currie Electro- Drive ® 450 Watt Motor System.
The Advantage: Powerful gear reduction motor system with chain drive power to the rear wheel.
The Benefit: Provides the power you need to climb hills or cut through wind. Rear wheel drive pushes the bike forward without altering its handling characteristics.
Battery
24V/ 10Ah Rack Mounted SLA Rechargeable Battery Pack.
The Advantage: Rider can easily move remove battery and add a second pack for extended range.
The Benefit: Easy to detach from bike when locking outside or transporting (to reduce weight). Carry inside to recharge.
Mode
TAG/PAS System
Electro-Drive ®
Battery
TMZIrocZ350
10-07-2015 12:09 PM
