Southern California Area Southern California Members.
SCTPI-hosted Dyno Day Saturday August 13th
Old 08-03-2011 | 01:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
http://www.socaltpi.org/forum/viewtopic.php?f=3&t=66
The dyno day will be held at our usual spot, MD Automotive at 9am.
MD Automotive
7281 Westminster Blvd
Westminster, CA 92683
The dyno cost is $75/hour. Plan on taking 1 hour for each car, including hook-up and un-hook time.
Sign ups:
1. Kevin
2. Don
3. Vincent
4. Raul
5. Peter
6. Tony
7. ??
Who am I missing?
Come on out and see how our TPI engines are putting down close to 400 horsepower to the rear wheels.
Old 08-03-2011 | 01:53 PM
Downshift's Avatar
Car: 91 Camaro Z28
Engine: 5.0L LB9 305 TPI
Transmission: 5 spd
Axle/Gears: 3.42 Rear End
re: SCTPI-hosted Dyno Day Saturday August 13th
I would want to but I am having a major drivability issue right now, hopefully I can get it figured out by then and hopefully there is still space available. If not, is it cool if I come down and spectate?
Old 08-03-2011 | 03:44 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Cool. I will come by and check things out. Should I bring some Donuts for everybody?
Old 08-03-2011 | 06:37 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
will there be a second date later on, im interested but i'm a month or so away from being ready.
Old 08-03-2011 | 07:50 PM
Car: 1989 GTA
Engine: 369 TPI
If things go according to plan my car should be ready sometime in September for a dyno session. I imagine we can get a few cars together to have another one.
Old 08-03-2011 | 10:14 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Can I go see even if I don't have a tpi or thirdgen?
Old 08-03-2011 | 10:18 PM
Car: 1989 GTA
Engine: 369 TPI
Sure. Come on by.
Old 08-03-2011 | 10:54 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Alright! I will be there then
Old 08-03-2011 | 11:26 PM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Depends how it goes for me on my work I mite pass by for a bit since I work that day at 1
Old 08-03-2011 | 11:39 PM
Kevin91Z's Avatar
Re: SCTPI-hosted Dyno Day Saturday August 13th
Of course you're welcome to come by and check us out.
Old 08-04-2011 | 06:43 PM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
I'll Probably Pass By If That's Ok With You Guys.
Old 08-05-2011 | 04:37 AM
thegooseman's Avatar
Car: 1992 RS
Kevin what time do you guys usually finish? Reason why I ask is because I work at six and need to be back in Glendale by 5:30.
Old 08-05-2011 | 11:04 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
KingsHustleLA
No prpblem, come on by.
Be there early and we will get you in & out and on your way.
Old 08-06-2011 | 01:11 PM
Parrydise7's Avatar
Car: 1985 Camaro
Engine: .040" over 350
Axle/Gears: 9-bolt with 3.45s
As long as I get permission from the boss I will be dropping by.
"I am the captain of the ship and I have my wife's permission to say so."
Old 08-06-2011 | 03:05 PM
Car: 1989 GTA
Engine: 369 TPI
Same here. I am the boss when the wife is not around. Maybe I will bring a couple of dozen donuts as the turnout maybe of fair size.
Old 08-06-2011 | 05:45 PM
Parrydise7's Avatar
Car: 1985 Camaro
I will match you on the donuts, just in case.
Old 08-09-2011 | 02:08 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
I gotta work, so I'll miss this one.
TA
Old 08-12-2011 | 03:32 PM
Kevin91Z's Avatar
I dont think we'll need 4 dozen donuts, but I'll bring home any that dont get eaten. A dozen from each of you would be fine.
See you tomorrow!
Old 08-12-2011 | 08:49 PM
Car: 1989 GTA
Engine: 369 TPI
Mark took home the left overs last time. So Kevin, you had better be fast or sneaky.
djmarch
05-08-2016 12:32 PM
83RDRACR
03-26-2016 09:13 PM
manifoldsrme
09-18-2015 12:40 AM
JamesC
Northern Great Plains and Rocky Mountain
09-10-2015 08:41 AM
BlackFormula
South East Region
09-08-2015 10:59 AM
