TPI Club March 26th Dyno Sign Up
I figured I would get one going in case this comes off. I bet we have some new highs. Maybe even some over 400rwhp. Lord, for once please let me have a "normal" dyno pull with a decent graph.
1. Dyno Don
2. Kevin91z
3. Allen
4.
5.
6.
7.
1. Dyno Don
2. Kevin91z
3. Allen
4.
5.
6.
7.
Re: TPI Club March 26th Dyno Sign Up
Damn...Only if I had the new motor in. Hopefully it will be in the car within a month.
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
1. Dyno Don
2. Kevin91z
3. Allen
4. VincentZ28
5.
6.
7.
2. Kevin91z
3. Allen
4. VincentZ28
5.
6.
7.
Last edited by Burnout91; 03-24-2011 at 10:37 AM. Reason: Added Vincent; 'hope it's cool!
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
Count me in tentatively for the 26th - that is if I didn't blow all my cash in Vegas.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I'm in for sure. Want to make a few changes. Going for 390+hp.
Car: 84 Camaro Z28
Engine: 355 Carb
Would it be okay if my friend and I go to see ur Dyno day
Let me know
Valentin
Let me know
Valentin
"Would it be okay if my friend and I go to see ur Dyno day"
Sure but you will have to get a "pass" with your photograph and sign a non-disclosure agreement. There will be a lot of "top secret" stuff there that is not for the general public.
Car: 84 Camaro Z28
Engine: 355 Carb
No problem I am not one to tell " top secrets" to the general public I been told a few things and seen Dons work and in fact I use it for my personal use only
I use all the advise Don has told me and it has helped me alot
I have no problem signing anything, I always carry a pen in my camaro
Valentin
Looks like the first 5 cars will be racing at the Invasion
By the way I confirmed the reservation for the dyno today. We are on. I plan on being there around 9:00am to get things set up.
"Anybody that tops this group will probably need a roll bar"
.....or gets booted after one pass.
I should make the lowest HP around 390+. I have the least and cheapest air flowing engine on paper.
Even though its not ready yet, do you guys think I may be 390+ with my new setup? I imagine my restriction would be the 1 5/8 headers. I know the miniram wont be.
Engine: Modded L98
I don't know, last time I made 375hp / 310tq through the SS4000 TC.
I just want to see the a/f ratio at about 12.8 - 13.00000 in the upper RPM's. I think it's a little lean up top right now. We'll see what the 'brain trust' thinks, and tune from there.
Bill
"Even though its not ready yet, do you guys think I may be 390+ with my new setup?"
Let us know where you are at in your build. What parts have you decided on?
"I don't know, last time I made 375hp / 310tq through the SS4000 TC."
Bill, high stall torque converters will do that. I lost horsepower on the dyno but went faster at the track. Did you resolve the lock up issue with your converter? By the way I had mine converted to an SS4000 as Dave says that looks to be a better match for my motor. I already have it back. I will not put it in until after the dyno pull on March 26. With the stock converter Kevin will be able to tune the car in more rpm ranges at WOT.
The motor is a Miniramed 355 with the AFR 195's. I went with the Comp Cams 280 XFI with a 114 LSA instead of the 113. I'm using 1.6 roller rockers with the 7/16 stud like you said. The exhaust is through SLP's 1 5/8 shorties with a duel cat y-pipe (made by DynoDon) through a 3inch magnaflow cat-back. I believe the compression ratio will be in the low 10's. I also had a performance build on the transmission done about two years ago.
Maybe. The SLP 1 5/8" headers maybe blocking the exhaust port more than I would like on those AFR heads. By the way Don has a set of his 1 3/4 headers that came off my car for sale if you want to upgrade. With a very minor clean up they are guaranteed to clear the exhaust ports on the AFR heads. However, they are set up for 2 3/4 collector pipes so you might want to upgrade that as well.
I guess you went with 114LSA trying to build some torque with the Miniram. I would have left it at 113LSA. You should make 390+ but at 6400. Your Miniram is open so much that you may not have enough cam for it. Bigger cubes would be better like 400+ cubes. For those of you that doesn't know, his Miniram flows over 390+cfms. It has a major port job.
I did what Don recommended. After finding out the what the miniramed flowed I brought up the idea to go 383. He said just stick on my current path.
I'm looking to upgrading the headers too. I'll probably wont do that for a little while though because of money. I'll enjoy the motor for a little bit, then upgrade when I have the funds.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Damn I need to get my ignition issue fixed on my TTA and get to this. I'm estimating 500 rwhp from the tire smoke dyno
Car: 89 GTA
Axle/Gears: 4.10
Maybe you have an idea? When I get above 3k RPMs I start backfiring. When I look at my ECM datalogger, the RPM trace starts toggling between 3000, 1500, and 1000... like I am missing signals from the crank sensor or the ignition module. I replaced both and still having the issue.
Car: 89 GTA
Axle/Gears: 4.10
I could bring my 5.7L Procharged, but it only has 7 cylinders atm if that's more fair
The latest on the weather, it appears that maybe there will be showers in the early AM on Saturday. That will work if it holds. We will have to wait and see.
I hope my gremlins are gone to so that I can make power beyond 5500 rpm. There will be some serious competition at the Los Angeles Invasion and I will need all the help I can get. The competition has not been standing still.
Axle/Gears: 9bolt
The race at the Invasion will be on a Sunday possibly Monday. We will vote for which day at the meeting. Looks like the weather is in our favor for this Saturday. If I get there first at the dyno I will go ahead and get things ready and put my car on the dyno to speed things up. If someone else is first we will put that car on the dyno to get things going. How many donuts should I bring? 1 or 2 dozen? Allen
Engine: Modded L98
I scratched my name from the list for March 26....vibration issue....again.
I would like to vote for racing at the Monday session of the Invasion.
Bill
Bill
Axle/Gears: 9bolt
Alan: Any donuts you decide to bring will be welcome. I'm sure they won't survive the day until dinner.
TA
#42
Bill, could it be that you need to rotate the drive shaft 180 degrees. It cured my vibration problem.
TA, I will bring two dozen donuts. The spoils will be shared to take home by whomever.
Edited: Corrected to 180 degrees.
#43
1 Post
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Bill, could it be that you need to rotate the drive shaft 90 degrees. It cured my vibration problem.
I didn't really notice my vibration until ~80, but after the ds was rebalanced I realized the vibration had been present at 25mph.
#45
Thanks Don, you are correct. By the way it looks like if there will be any rain it will occur in the evening or late afternoon. So we should be able to get out dyno runs in.
#46
Car: 89 IROC Z-28
Engine: 5.7
Transmission: A4
Don't forget the VHT for the rollers!!! You guys are gonna need it this time!
I wish I could come by to watch, but Saturday is a work day for me. Have lots of fun.
#47
Car: 1991 GTA
Engine: 350 tPI
Axle/Gears: 342
I'd bring coffee to go with the donuts, but I have to work at least part of the day, so I opted to work in the AM.
#49
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
#50
A certain '65 Chevelle with a different kind of tuneport would like to join us.
1. Dyno Don
2. Kevin91z
3. Allen
4. VincentZ28
5. Bruce
6.
7.
1. Dyno Don
2. Kevin91z
3. Allen
4. VincentZ28
5. Bruce
6.
7.
