So Cal Emissions Test
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
My car passed smog today Visual (yep!), functional and tail pipe checks. No special prep, other than driving it in a spirited manner for about 15 minutes before rolling into the Test Only Center. But, it didn't just pass; tail pipe emissions measured less than half of that of the average car tested, and were waaay less than the max allowed. It runs very cleanly.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: So Cal Emissions Test
Way cool Bill
Congrats>>>
Don>>>
Congrats>>>
Don>>>
Engine: Modded L98
Yeah, it just makes me want to tell someone, someone who has sense and who can change the rules under which our hobby is governed, that you can modify an engine and drivetrain (to the hilt, if done correctly), and still be very eco-friendly. And, tell them that we have proven, with their own testing procedure, that we know how to do it. For now, however, it will be a somewhat guarded secret amongst those in the know.
Bill
Bill
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Now call Holley and tell them what happen and what to do.
This makes me feel comfortable that you passed visual. I'll be using the miniram with the egr setup.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
WHAT YOUR VOTE MEANS
YES vote on this measure means: Certain existing and proposed regulations authorized under state law ("Assembly Bill 32") to address global warming would be suspended. These regulations would remain suspended until the state unemployment rate drops to 5.5 percent or lower for one year.
NO vote on this measure means: The state could continue to implement the measures authorized under Assembly Bill 32 to address global warming.
I think you want to vote YES on prop23 if you want to suspend implanting AB32
Engine: Modded L98
Mod your car correctly, and you will have a lot fewer worries from / about the douchebags (sound familiar???) in office.
HSR ROCKS!
Bill
HSR ROCKS!
Bill
Engine: Modded L98
Passed again yesterday...with mods in sig....no prep, no payola. Test Only station in Los Angeles County. Same station as the last few years, different tech this time. Didn't really look at the allowables to see if they had changed, but my numbers, although higher than last test, were at about 1/3 of what the average car that passes puts out. Clean machine.
Hardest part of the test was getting backed out of the test stall...stalled 3 times. Gotta fix that...reverse comes in really handy.
Bill
Bill
1 Post
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
I was having issues with my car but had to get an illegal smog so they would stop feeing me and the car could be somewhat drivable still got issues to work out but would like to know how you passed
Engine: Modded L98
"Passed again yesterday...with mods in sig....no prep, no payola. Test Only station in Los Angeles County. "
That's how.
That's how.
Thats a handy link muIIet.I barely passed (again) by one point on HCs.Failed first time, NOX was a big fat zero on both 15/25mph, but HC & CO were 11-17 points to high.Adjusted my TPS from .33v to the proper .48v & my EGR was not closing completely, fixed that & went back.
Results:
HC @ 15mph 92, max 93ppm -@ 25mph 71, max 75ppm.
CO @ 15mph .28, max .57 % -@ 25pmh .39, max .43 %.
NOx (meas) was 31 & 0 ppm respectively.
To be honest though.I still dont know how it managed to pass w/ the max #s set so low.Two more years of hassle free ownership!
Results:
Two more years for me too.
Passed with good numbers.
HC 11 @ 15 .....22 @ 25
NOX 186 @ 15....136 @ 25
CO @ 15 .01....25 .02
Engine: Modded L98
Passed smog test today, at a STAR Station, on the second try. HC was 1 point high (59 ppm) first try at 25 mph. O2 sensor was 'lazy.' Replaced sensor with OEM ACDelco sensor, and passed well below limits, pretty much below the average of cars that passed. Mods in sig are current.
Yippy Skippy!
Bill
Yippy Skippy!
Bill
1 Post
Car: magflato
Engine: magflatoVE
Transmission: magflato
Axle/Gears: magflato
Nice. I will be doing my smog test in a few months. The crazy person the had my beauty before me had swapped the heads out with what I believe to be pre 1976 SBC heads. There is no egr port on the head to intake mating face. So I get a code thrown for egr fault.
Car: '85 Trans Am
Engine: 305 LG4 4BBL
Bill
Bill
hahah nice thought...good luck with that!
Hotrodboba400
12-10-2019 07:07 PM
raymondandretti
09-27-2015 06:43 PM
