2 Magnaflow catalytic converters for sale
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
2 brand new cats for sale. They are stainless, 3" in/out. bought these then saw dual cat conversion wasnt allowed for a single cat set up. Im selling both because my current cat is about a year old(same type), but I was going to run dual cats so I wanted them to both be new
120 each or 200 takes both. Would prefer to do this locally, but can ship at buyers expense. Im located in 92507.
Car: 1987 z28
Engine: 305tpi
Re: 2 Magnaflow catalytic converters for sale
I got them at a local exhaust shop with no box. The cats do have these inscribed into them
CA/CE 99000
94000 11 07
I looked that up and it comes up as the series. They do have an air tube, I passed smog easy when I had a 305 with stock tune and 24lb injectors
CA/CE 99000
94000 11 07
I would just convert to duel cats anyway. I doubt the smog people will give you any crap. If they do just go to the next location.
Car: 1987 z28
Engine: 305tpi
It would also require quite a bit of work. Though if they dont sell Ill try. The main thing was the smog, and I havent found a shop that can mandrel 3"
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
It will be about the same if buy a 3in cat back system and have some one local to install it for you. What part of Riverside are you in?
Car: 1987 z28
Engine: 305tpi
Close to downtown riverside. Chicago and colombia area. How much would that run? (feel free to pm me)
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
If it does not have an E.O. number, it's a visual fail when it comes to smog check.
Not correct Vince. They can fail you if it appears that you have had old style catalytic converters installed post December 31, 2009. You have to prove via documentation (receipt) verifying that the converter(s) was/were installed before said date. If you can’t produce ‘proof’ of installation the smog station can fail you for having installed an old style converter after the law changed. I know because it happened to me a couple of months ago. I was able to ‘produce’ a receipt stating that the converter was installed in October of 2008 when in actuality it was installed in August of 2010. Smog shops are getting extremely difficult to deal with especially since the laws changed. California wants our cars off the road and crushed.
Well if that's the case then always go to the same smog station that knows your car and it shouldn't be a problem.
You can install an old style cat but you have to make sure that the production date coincides with the date you supposedly had it installed. For example, production date on the cat of 7/2008 and a receipt showing it was installed on 9/2008 no problem. A little paint for good measure doesn't hurt either It takes some research but with the right cat it can definitely be done…
Car: 1987 z28
Engine: 305tpi
Nope, I had to go to a different smog guy this year because the one I had been going to for the past 6 years (who is extremely familiar with 3rd gens and has been for quite some time) was reluctant to touch my 100% stock LO3 even though all of the factory equipment (air cleaner, heat riser, exhaust manifolds, brand new egr valve, etc.) was in place. He did a couple of pretests for me which is how we discovered that the car needed a cat but was quick to tell me that he was going to check the cat after I had it installed. If it wasn’t one of the ‘new’ cats then he wasn’t going to touch the car. So I installed an old style cat and had to find another shop that was less then familiar with 3rd gens to smog it.
As for the cats for sale, I have the converter warranty cert/ installation statement for both cats too, if needed.
Guest
Posts: n/a
1992 Trans Am
05-10-2023 07:19 PM
Chuck84TA
07-15-2016 09:05 PM
