SoCal TPI forum is now live!
Thank you all for your patience, as our forum for the Southern California TPI Organization is now live and ready for your posts!
http://socaltpi.org/forum/
Registration is done manually by me, so please allow time for me to approve your login after you sign up.
I look forward to discussing all the latest and greatest ideas to make the TPI engine a stronger performer on our own board now.
Re: SoCal TPI forum is now live!
I've rec'd a request to lock this thread. I'm going to give them a little bit of time to get their legs under them over there. There still appears to may be glitches logging onto the site. Once I've confirmed they can post over there and are not having problems, the moderators should follow the same criteria that is being applied to the SC3G threads (requesting posts be made on the their web site and lock to the original thread).
Lon
Lon
Ringo, try again. You can refresh the code to try for a better one, but the code is required to try to keep out spammers.
If SC3G wants to lock their threads and direct traffic to their boards, that's their right to do so. However, that does not affect SCTPI threads. That's two different subjects.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Registered under (91RSB4C)
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I'm not in So-Cal to enjoy the fruits of all your TPI labors in person, but I do read some of your thoughts and ideas in here from time to time.
Also, came across this thread below in the vendor board that may, or may not be of any interest. More so to me for some generalizations made about TPI owners.
https://www.thirdgen.org/forums/afte...ml#post4640271
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Come on out and join us this Sat. nite at Denny's
https://www.thirdgen.org/forums/sout...t-meeting.html
Sanjay
08-12-2015 03:41 PM
california, camaro, foru, forum, forums, generation, organization, port, secrets, socal, socaltpi, socaltpicom, southern, tpi, tuned
