CA smog nazi's
#51
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Re: CA smog ****'s
#52
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
Re: CA smog ****'s
well just a curious question..is anyone here smoggin stock? i think injdinjn is so far stock as he said in a reply..but i mean is any one smoggin BONE stock like no add ons 50 state legal blah blah woof woof...?
i gotta smog by the 10th.. n well i got a mild cam n aluminum heads with an adjustible fuel press. reg.
i barely passed 2yrs ago also with that set up but it was my issue that my timing was off.. im just hoping this time ill be cleaner that ill barely pass again.. ..if not ima hafta call my buddy
#53
Re: CA smog ****'s
I smogged stock (88 IROC with LB9 and 5-speed) and passed about a month ago. Made sure it was good and hot, and left it running while waiting for the smog tech.
I was plenty nervous during the test though.
#54
1 Post
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
Re: CA smog ****'s
except for using an '89 chip, i smogged stock. 186k on the engine. used 91 octane and got it nice and warm. it was pretty clean i can post the numbers later if you want.
was mostly nervous because the valve seals are bad and can get a huge puff of smoke on startup. i made sure to start it a few times before showing up.
#56
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
Re: CA smog ****'s
i'm taking my stock '84 Z28 (lg4 carbed) to get a "test run" done at a local junior college. i'm taking an engine rebuilding class this fall, and the guy who runs the program said they were teaching a smog tech class and i could bring it by and they would run it and check it out. I highly suggest people trying this if you think you're going to fail, better than wasting money on a run. I'll post my numbers of both the pretest and when i actually go to get the test done.
#57
Re: CA smog ****'s
I just smogged my car today. The max numbers are the same numbers they have been for years.
1983 LG4 T5
MAX HC @ 15 - 130 ppm (15)
MAX HC @ 25 - 103 ppm (13)
MAX CO @ 15 - .94% (.13)
MAX CO @ 25 - .74% (.21)
MAX NO @ 15 - 1106 ppm (316)
MAX NO @ 25 - 936 ppm (323)
1983 LG4 T5
