one step closer and a special thanks
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
as most of you guys might know, i decided to convert from tbi to tpi..
well im to the point where i just need to drop the engine, plug everything in, and swap the fuel pump...
well i couldnt have done this without your help
first off thanks to
kevin91z... for helping me get some good rods
vincentz28...for helping me with the wiring (bassically letting me know im way off on my wiring n leading me to the right path)
Mr.Dyno Don.... for taking me step by step on the process on my wiring harness (what to buy, what to avoid)
topteam54...for getting me the correct ecm for my conversion
LAFireboyd-tips as well as advice
and mr JERRYWHO..for getting me the last parts i needed
if i forgot someone else let me know.... this ones for you *Drinks beer*
thanks fellas, hopefully this is it for my thirdgen and i can finally enjoy it like i did when i first bought it
first off thanks to
![Name: motor.jpg
Size: 57.6 KB](https://www.thirdgen.org/forums/attachments/southern-california-area/412725d1501465740-one-step-closer-special-motor.jpg)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: one step closer and a special thanks
Now this is what it's all about...glad I could be of some help.
Thanks for the kind words![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
BTW: that tube that is sticking up on the left header, you can remove that, it isn't needed for TPI.
Gunner242
12-25-2015 04:49 PM
