does this mean i need alignment?
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
lol
i also found a busted balljoint.
been waiting for theses the past 2 months.
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
Re: does this mean i need alignment?
you might
i have the same problem but my car tends to steer towards the left
does your roc steer to the right?
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
so i changed a ballpoint and i decided to ditch my whole brake set up as well
Sick CTVS brake set up, can't wait to check it out first hand!!!!! I wonder if my ball joints are shot too, never got around to greasing them up.
Car: 88 Iroc-z28 Convertible.
Engine: TPI 5.7
Transmission: 700R4 w/mild shift kit.
Axle/Gears: Stock.
Firestone used to offer a lifetime alignment as long as you own the vehicle. The did a good job on my IROC back in 05'.
1 Post
Car: 1986 Grand Prix TPI
Transmission: 200 4R
You tell Accurate how you drive the car and he will set it up accordingly, firestone, sears etc set it up to factory specs only unless you give them the specs you want and they still might not do it right.
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
i was actually showing off my new brake set up lol
day and night difference
Did you get a right and left rotors. The first picture of the car shows you have the driver side rotor on the pass side.
Jerry
Jerry
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
ctsv
yeah that what i though too! lol gm doesnt have a L or R rotor for the c6 z06. its like that on a lot of vehicles equipped with drilled rotors.
