Southern California Area Southern California Members.
Cut the bull, Time to go racing.......
Old 04-08-2010, 09:12 PM
  #51
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Cut the bull, Time to go racing.......
Hmmmm, we need to figure out why you are not getting good traction. Maybe front brake line lock for a decent burnout?
Old 04-09-2010, 08:56 PM
  #52
Car: 1989 GTA
Engine: 369 TPI
One more thing Jon. When your car was on the dyno you could hear the exhaust struggling to exit. A couple of people commented on it including the dyno owner. So yes, I bet you picked up a good amount of power and that was reflected in your mph.
Old 04-10-2010, 11:05 AM
  #53
slow91camaro's Avatar
Car: '91 Camaro Z-28
Transmission: auto
1989GTATransAm Hmmmm, we need to figure out why you are not getting good traction. Maybe front brake line lock for a decent burnout?
Burnouts are not a problem, I usually lay into them pretty hard and wait until I see a good amount of smoke before I pull out of the burnout box. My first burnout might have been a little weak but the 2nd and 3rd should have been more than enough.
The tires are few years old so maybe they're not as good as they once were?
Then again my posi has nearly 140,xxx miles on it so maybe it is giving up a tad?
It always leaves two stripes on the street but maybe the stickier tires are too much for it to handle. Should my suspension/tire combination be able to easily provide traction for the amount of power the motor is putting out?
Old 04-10-2010, 11:07 PM
  #54
Car: 1989 GTA
Engine: 369 TPI
"Then again my posi has nearly 140,xxx miles on it so maybe it is giving up a tad?"
Don can put your car on the rack and check the pose pretty quick. Mine failed the test and had to be fixed. I gave him a punch of posi-shims that were ordered for my car. We just need to get you squared away for the Invasion. I think a bunch of us are going to show the 4th Gens how it is done at the track.
Jeremys87
07-14-2022 09:08 PM
Leggman1
Brakes
08-12-2015 08:39 PM
TA8487
08-11-2015 09:02 PM
apie2546
08-08-2015 07:12 AM
Quick Reply: Cut the bull, Time to go racing.......
