Iron Duke Baby!!!
Iron Duke Baby!!!
http://losangeles.craigslist.org/wst...596513340.html
Talk about a rare bird... Better get it while it's hot!
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
Re: Iron Duke Baby!!!
"First time a 4 cylinder was available in a Camaro. The compound curved rear hatch glass at the time was the most advanced piece of glass tech-wise to be put onto a car. It was also one of the most aerodynamic cars ever produced. "
I don't think reducing drag makes a difference at or below 45MPH.
But I will say it's a nice grocery getter if your other thirdgen is temporarily on jacks... maybe not for 3.5K tho.
Guest
Posts: n/a
As funny as you guys think that is, I will tell you what....
...I slap this puppy into there at 300hp and only 318 lbs and I have one bad *** little lightweight road car.
http://www.race-cars.com/engsold/oth...34283533ss.htm
Guest
Posts: n/a
What the hell's that suppose to mean.....LOL ...the bad part is I can interpet that about three different ways. I guess I walked into that answer and deserve it, ouch.
1) I forgot the meeting I said I would attend
2) I have too many cars already and no where to park another one.
3) someone would steal it, or "borrow it".......Tom?
Am I anywhere near on track to that comment?
Car: 1986 Camaro
Engine: 350-Carb
Transmission: 700-R4
Guest
Posts: n/a
LS1 is 430 lbs
The 60* V6 is about 375 lbs... which I have already built and proven to be deadly but lacked straightline HP at 160 flywheel HP.
Sooo... Dropping even another 60 lbs and adding twice the HP from what I had? There ain't a 3rd gen alive that would touch it on a road course or autox.
100 lb drop of weight off the nose is major... this is more like 250 lbs which woulld put me at about 52/48 bias.
You need to read up on my old Camaro's specs. I have already proven what you "speculate" to be wrong.
edit: I would still rather build a TTA though- that would be my dream. I think i could build a tta with a all aluminum motor to top 200mph and run Nurburing and outrun the best exotics with the TTA car plus a 75K budget. I would sure have alot of fun trying.
Car: 1986 Camaro
Engine: 350-Carb
ok i get that weight makes a lot of difference in acceleration, speed, and how it handles but also how much weight difference is there from the iron duke and that pontiac 4 cyl engine?
Idk why u would want that engine in a third gen tho. If a 4 cyl was to go in a thirdgen it would be an ecotec for me. Add better injectors, boost, exhaust and u got 300+ hp! and more reliable than the other one!
Although i do think a light engine that makes power in autocross would do quite good vs other thirdgens.
But with that said, idk what else they would be able to beat? If i were going to run a car in autocross, my first choice wouldn't be a thirdgen. And if i had enough money to put a strong 4 cyl in a thirdgen, well that engine wouldn't be in a thirdgen! Idk i guess its all subjective and like i said im not saying u were really wrong, just that i wouldn't put that 4 cyl in that camaro.
IMO
IMO
Guest
Posts: n/a
That superduty 4 motor is still extensively run in IMSA today. It also ran in a NASCAR truck series. They are called SD-4 motors and are for the most part "HALF a V8" Motor. They use a SBC Or in this case a Pontiac (interchangable) V8 cylinderhead.
These motors have INCREDIBLE low end torque. A Honda V-tech does not have crap in the torque department. It is more of a lightweight rpm motor and would suck in a Camaro at 3000lbs
Guest
Posts: n/a
There are companies that make all aluminum SD-4's but of course the $$$$ goes way up. Kansas Racing Products for one (KRP). but at this point, the ultimate would be to go Cosworth at $20,000, but that goes against the basic Iron Duke format this SD-4 motor stays under
Guest
Posts: n/a
blackz281le
01-11-2016 07:51 AM
redformula88
10-14-2015 06:08 PM
