Smog Test
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Smog Test
Another excellent tuning job by "Kevin91Z"
Car: 89 IROC Z-28
Engine: 5.7
Transmission: A4
Re: Smog Test
That Kevin91Z is one amazing tuner!! He impresses me with his abilities at every dyno session as well as on smog check day.
So now we have to look at just a LITTLE more cam and another 1/2 point of compression for that little 355!!!
Re: Smog Test
Geez, that's cleaner than my car was!
I dont deserve all the credit though. Don helped.
Also, he just finished rebuilding my T56 and its now smooth as glass and shifts like a knife thru butter.
New cam already, Pat? Now we know why you had Don install it in his car first. He can work out the bugs and find out the power, so you know what to upgrade and replace before it goes in your car.
I'd recommend a 224/230 from Comp using the XFI ramps and 113 LSA. That's halfway between the XFI268 and XFI280.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
Car: 89 IROC Z-28
Engine: 5.7
Transmission: A4
Re: Smog Test
But VINCENT is gonna have a BIG cam, can't i have one too??????
They say you can tune ANYTHING!
thanks Kevin, you da man!
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: Smog Test
all the cams you guys are talkin about...they will pass the sniffer test? also how do these cams run with a LTR setup...will the cams still have good lowend in a 355?
raymondandretti
09-27-2015 06:43 PM
