CA law on cut outs
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
legally, it has to be after the cat.
after that though, almost anything goes as long as it has reasonable sound supression...
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
What the hell you need a cut out for on a 14 to 13 second car for anyways. You are not going to go any faster by making all that unnecessary noise. Don't even waste your time and money on that project. Only ricers do that and look how fast they are going 15 to 16 seconds.
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Well I'm getting one so that I can have an open y pipe when I want it, and when I want to be quiet, I can be that too. Not to mention that my TA is called 'Budget TA' for a reason lol. Cheaper than a good exhaust to just get a cutout.
You should be fine if you mount it behind the cat, because then all you're doing is changing the noise levels, not the emissions levels. Just don't rev at a cop with it open.
Originally posted by KiLLJ0Y
vincent, this is AFTER the heads and cam swap. im not doing this now. i just wanted info on this for future reference.
It is not necessary for a cut out because our fuel injection engine likes a little back pressure. If you are running big horse power then a full open exhaust. It looks embarassing running 13's or 12's making up a bunch of noise. Myself and a few others are running 12's through the mufflers.
If it don't make horse power it don't make sense
Just run dual cats and there you go. Cool sound an all
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Backpressure kills horsepower. The only engines that "like" backpressure are 2-strokes.
Right the cut out is just non sense. You will make so much noise going down the road or track. No sense for any more. However if you want that kind of cut out it might be cool for track purposes.. But Im sure there are other area's you can still gain hp..
I myself am thinking of having my exhaust made like Kevin's since we pretty much almost have the same exhaust any ways. But Id like to add in the bullet muffler. And do that trick Bend Don does over the rear.. That is probably crucial there to have a nice flow mandrel bend over the 3". And also I like that the exhaust is nicely able to all unbolt. So if you want to really make some noise saves some weight. Run it where legal. if the car likes it.. But each to there own..
Guest
Posts: n/a
well i was just gaining info for the future so i dont go off and buy one not knowing the laws..
the use would be only for off road and scaring old ladies, the damn kids next door, and waking up the dead at 1am.
i need to replace my cat because its basically gone, so i think i might have Don work some magic and make a dual cat like all the cool people.
wait is a dual 3" cat system even doable? my Y pipe is 3" and the rest of the exhaust is the mandrel bent 3". i guess i would have to change the Y pipe situation then. eh, either way.
my objective is to be faster than Vincent
JK Vincent
JK Vincent
My car is pretty loud with 2 gutted cats an a 3in catback American Thunder System. And it sounds good too!
Originally posted by 1989GTATransAm
And on the fast side. I may have to go with the gutted cat option. :hail: Allen
You want to be loud unbolt that sucker. Less weight. And it's going to give the flow all the way around. And if you have the advantage of 1 3/4 headers, you might as well use it.
Listen to the story's Don tells. Even about Converters in both area's. There is always a gain.
Vincent's car may sound nice. But you have to admit. That's Cam.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I got my cutout because I wanted the option to have the Flowmaster sound...and then the Raw Nascar sound...especially by just flipping a switch (McCord Power Plate). Unlike alot of guys...I could careless if it made any power or not. I agree for the guys that want to race..and that's all...but..if you just want a cutout so you can make it as loud as possible...then go for it...but for race reasons...I probably wouldn't go with one. Just stick with a full length 3 inch exhaust My car is just for show...and once in awhile, I drive it....but that's it.
In my opinion I love having cut-outs. Like 84 Custom said I love having a quiet exhaust and then flipping a switch and having a loud throty sound. In my car even gain around 15 rwhp with it open. And I have changed my whole exhaust. I have to smog my car in a bit so I will tell you if I pass or not.
Peace Out,
PsychoGTA:lala:
Peace Out,
PsychoGTA:lala:
Transmission: 5 spd
Peace Out,
PsychoGTA:lala:
Peace Out,
PsychoGTA:lala:
Terrell351
06-13-2021 01:13 PM
db057
08-11-2015 10:11 PM
