WTF? PF-25 oil filter discontinued?
Dealer says that the stock PF-25 oil filter has now been discontinued by GM. The new "replacement" filter is smaller in size. That don't sound good to me. Less area means less filtration. Correct?
Went to another Delco parts place and they say the same thing. PF-25 is discontinued. WTF?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Yep, gone! That new PF454 filter is a joke. Get the PF1218 filter. It is bigger then the PF25 though, more like the now disc PF35.
Dang! How can they get away with that? If the original specs call for the larger PF-25 filter and then they replace it with a much smaller filter, then something is seriously wrong with GM.
I sure hope they don't discontinue the PF-1218 anytime soon. Keep your GM car ALL GM. Yeah right! How can you when they're discontinuing everything including the oil-filters.
What's next the sparkplugs?
They told me at autozone and kragen that they were discontinued a long time ago - autozone lists that little tiny one in their computers but not 1218. For that reason you can just about always find the 1218s at autozone. Might want to stock up, though
1 Post
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Get your local, non chain, parts store to order you a WIX filter, I am pretty sure they still make the original sizes and they have much more filter material on the inside.
Car: 87 IROC Z
Engine: 5.0 TPI
Just wondering what makes gm better than a fram or any other aftermarket filter? Someone said wix has more material inside. that brings up interesting subject. And when i get bored and destructive at work i may have to find out if stock acdelco or cheap Mighty filter or different inside. And if i buy mine own wix filter and try it i could compare. But are wix more expensive than fram or delco filters?
1 Post
Engine: 305 TPI (LB9)
Transmission: WC T-5
Hmm... I guess it's been more than a few months since I bought one. Good thing I stocked up last time I was at the store!
Wix filters are very good quality, as are Baldwin filters (if you can find them). I believe Napa filters are manufactured by Wix. Wix and Delco are about comparable in cost.
Mighty filters?? I wouldn't put those on a Yugo...
Car: 1987 Black IROC-Z (SOLD)
If you want to use a 2-qt filter try the a/c delco PF-935 which is a replacement for the older numbers. It is the longer one and I have no problems with clearance. Its nice to have a six quart capacity.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the K&N filters are nothign but a rebadged Fram filter that has a sheetmetal nut spotwelded on.
i just put a PF454 on my camaro.. i was thinking to myself, damn... it has been awhile since ive worked on SBCs.. this filter seems small, and i though the number was two digits..... lol
this explains that. :lala:
Car: 91 Camaro Vert
Originally posted by rezinn
How could you even put that thing on there without noticing how small it is? It probably hardly holds half a quart of oil :P
this time i had to get the "car" one since the oil cooler adapter would make the other one lower then the oilpan and Kmember.
i didnt remember it being that small either... lol.
i'll jsut get a bigger wix one next time. i change the oil every 2 weeks anyway...
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Considering that a PF454 is $4.50 in my area, not too shabby.
Car: 91 Camaro Vert
btw, i doubt the filter will ever go away completely.
GM might not make it, but they used the same one since the late 60s until the LT1... and even then, im 80% sure you could screw it onto the LT1.. lol.
they'll always be filters for the SBC.
Hotrodboba400
12-10-2019 07:07 PM
89 formula TPI
09-07-2015 11:06 AM
