driveline/drivetrain shop needed please!
hey'all looking for a good mechanic or driveline/drivetrain shop that can take a proper look under my car and possibly install & balance a new driveshaft... i'm in the Torrance/South Bay area
recommendations please | thanks! Brian
ALSO | if anyone has an aluminum driveshaft for sale or knows of good yards to get them from, please post!
1 Post
Engine: 305 TPI (LB9)
Transmission: WC T-5
If you're looking for someone relatively close to you, there's Drive Line Service in Gardena (310) 515-2860 Don't have any experience with them, so I couldn't recommend one way or the other.
I have, however, heard that Red Bull's Differential Repair in South Gate does pretty good work. They do driveline work as well. (323) 707-3113
What car are you looking for the d/s for? Your '95?
Yes, it's for my 95 | thanks for the #'s.
From what I've read & heard the 1LE aluminum driveshaft is the same for third & fourth gen vehicles. 2.75'' diameter.
My other option is an LS1 alum ds. I'll give those shops a call now.
No mods no stickers heh
2.8... what/who/where is ACPT? Are they www.acpt.com ? that seems to be the only match and they manufacture
composite driveshafts ? sounds expensive!
now that i've taken a look at the LS1 vs 1LE driveshafts, i assume the vibration damper is the round disc on the front yoke?
do you recommend changing ujoints and endcaps (in addition to balancing) before installing the driveshaft?
if i do that, will they still use the original yoke with damper (or no damper)?
thanks!
thanks!
1 Post
[i]do you recommend changing ujoints and endcaps (in addition to balancing) before installing the driveshaft?
[i]if i do that, will they still use the original yoke with damper (or no damper)?
1 Post
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: driveline/drivetrain shop needed please!
It's probably a bit too far for you, but WENCO in Van Nuys does good driveline work.
kah992
08-19-2015 02:55 PM
