comp cams 1.6 roller rockers (new in box) $140
Car: 1986 z28
Axle/Gears: 3:73
brand new in box comp cams rocker arms for small block chevy
Rocker Arms, Stud Mount, Roller Tip, Steel, 1.6 Ratio, Fits 3/8 in. Stud, Chevy, Small Block, Set of 16
http://www.summitracing.com/parts/CCA-1418-16/
Rocker Arm Mounting -Style Stud
Rocker Arm Ratio -1.6
Rocker Arm Style -Roller tip
Stud Size -3/8 in.
Shims Included-No
Rocker Arm Material -Steel
Self-Aligning -Yes
Rocker Arm Body Style -Standard
Rocker Arm Nut Style -Self-locking
Slot Style -Long
Maximum Spring Diameter (in) -1.500 in.
Rocker Arm Finish -Natural
Stud Size -3/8 in.
Shims Included-No
Self-Aligning -Yes
Slot Style -Long
1 Post
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
Re: comp cams 1.6 roller rockers (new in box) $140
PM SENT.
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
