Accel Superram
Accel Superram
Has anyone here in the Phoenix area ever done an Accel Superram install? I have owned one for about 10 years and never got around to installing it. I know it can be a bear to install but apparently once you do it and understand how its supposed to go together it's not so bad.
I am thinking about taking on this project and was wondering if anyone would be interested in joining in on the install. Will probably just do the upper intake. I generally enjoy working on projects with other people then just by myself.
Thanks Brian
Thanks Brian
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Re: Accel Superram
would enjoy helping out, unfortunately im about 800 miles away.
i have lots of tips and can send pics if needed. Plus there is a gang of folks here and on the corvette forums that can assist and help things go smoother for you.
Re: Accel Superram
I guess that is a little far away. If you have some specific tips and pics that would be great. I going to pm you my email address. If you have a chance and can email some pics of the install that would be really great!!
Car: 91 Camaro RS
Engine: 305 TBI
Re: Accel Superram
I would be willing to lend a hand. I am not very knowledgeable, but I do what I can like rad, water pump, etc. Downside is I have no idea about the superram, but the upside is I'm close and willing. Let me know.
Re: Accel Superram
Copchaser already sent me some good instructions and tips and I may broadcast the install with my mobile web cam for all to see.
1 Post
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
Re: Accel Superram
That sounds good! Does not matter if you do not have any experience with it. I will be doing most of the wrenching and hopefully we will both learn something in the process.
POST PICS OF THE INSTALL. YOUTUBE VIDEO OF RESULTS ETC...
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Accel Superram
I always use quite a bit of RTV on the runner gaskets... Superram's are known for having vacuum leaks around the runners. I have installed mine prob around 4 times now... All I can say is I ended buying a few small tools to make the install easier/faster. Use bolts for under the plenum (along with a ratcheting wrench). The allen head ones suck!
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: Accel Superram
I worked on one several years ago, but would be willing to lend a hand. When are you planning on swapping it out?
Re: Accel Superram
they are not the pain that every one says they are.. you just need to know how to install them.
i have been running the super ram for over 19 years
on a few diff engs.
can tell you that it takes alot more time to install then any other.
only 2 screws are a hard get to..(2 on ea side)
and remember to run the kick down under the top box.
never had a leak with mine or others.
use a small bit of RTV (just enof to cover the gaskets)color
i use ultra blue. use rubber gloves to apply it to the gaskets
done right. you will not see the RTV. and it will not Leak
on a few diff engs.
Re: Accel Superram
Sunday I am going to help birdtojag (Chris) with his car.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: Accel Superram
Brian you don't want to install that difficult old super ram.....Just give it to me and save yourself the trouble. :-P
Def take some pics of the install as it goes if you can.
Re: Accel Superram
Always wanted to see that Superram in your car. Hope it all goes smooth for you.
Re: Accel Superram
If you decide to change your mind on using the superram, let me know if you will sell it for my offer of $700. 661-718-7047 or email me at paterrachevy@yahoo.com
Pac J
05-17-2020 10:44 AM
efiguy
09-27-2015 01:30 PM
e3pres
09-09-2015 01:51 PM
