South West Region South West regional discussion board.
Anyone have a camaro inside door handle?
Old 04-26-2011, 11:22 PM
ChainHartMachin's Avatar
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
My inside door handle just broke on me, anyone have a spare I can purchase? Thought I'd ask locally before looking on ebay...
Old 04-26-2011, 11:39 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: Anyone have a camaro inside door handle?
Advance had to order me one but it was only about $20.
Old 04-26-2011, 11:56 PM
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Just found that autozone has them under the HELP! brand. Guess I'll have them special order one for me. Thanks for mentioning that you got yours from advance! Saves me some time!
Old 04-27-2011, 12:02 AM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
i got one that was sitting in the backseat of a parts car i bought was just laying there idk the brand, i can check to see if its GM if u want, i know the "HELP!" (doorman) window cranks are junk so idk if the "HELP!" door handles are better lemme know
Old 04-27-2011, 12:09 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
I have 1 or 2 10+shipping
Old 04-27-2011, 12:14 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
You can find them on ebay(New.) for 10.00 with free shipping. Just dont get the dorman one, they are JUNK. The one I used on my '90 didnt even last 2 months.
Old 04-28-2011, 12:56 AM
TGO - 10 Year Member
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
just a heads up its riveted in, my cousin snapped mine clean off and i had a spare, you have to pop the door panel, drill out the rivet and then it slides forward and out, cant remember the rivet size but you gotta put it back in with a rivet gun
Old 04-30-2011, 12:02 PM
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
The rivet must be 3/16" as the 5/32" rivets I had in the garage last night were not big enough.
I ended up using a small screw with a lock washer on one side and loctite on the other. If that doesn't hold up I will use a rivet.
I also found that one PO or another did a horrible job of replacing the driver's power window motor. Used four random bolts to try and hold it in, but only two are actually holding it. The mounting holes around the others are cracked. I'll fix it another time.
Does anyone know where to get the rivet gun and rivets for power window regulators? The rivets are huge!
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
BlackTopKing
08-19-2015 12:13 PM
89lsc
08-14-2015 04:58 PM
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
Quick Reply: Anyone have a camaro inside door handle?
