How about a Arizona Part out alert thread??
#101
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
Re: How about a Arizona Part out alert thread??
http://phoenix.craigslist.org/wvl/cto/2346236496.html
THIS MITE BE GOOD.....
#102
http://phoenix.craigslist.org/evl/cto/2344485055.html
THIS IS THE BEST IVE SEEN TO DATE...
#103
http://phoenix.craigslist.org/nph/cto/2343799484.html
ANOTHER GOOD ONE. NEEDS DIFFRNT WHEELS BUT REST OF CAR LOOKS GOOD.
#104
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Well if you need parts there's a quite a few thirdgens up here, I've shipped parts back and forth to chris (birdtojag) a few times, let me know if you need anything, most of the people up here use cascadecrew instead of tgo, more of a local feel to it and everybody has got smethin lol
#105
WHAT DO YOU GUYS DO ABOUT CORROSION FROM THE WEATHER IN WA ? MY CAR RUSTED WHEN I WAS THERE FOR 2 YEARS..
#106
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
To be honest I'm not sure, I've only been back a year, I picked up the camaro when I was in highschool in az, haven't had any rust that I've found, apart from the a arms and such but that's expected the clear coat has gone to crap tho from the rain, az sun baked it now the rain is washng it off lol
#107
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
You aint kidding! Those hard lines are hard to come by! I couldnt find any for a good price and you know, If I cant find it!!! LOL, make sure you remember; The TPI serp and v-belt cars use a different set of hard lines for each one. You saw my IROC when You were out here, Andy... Remember what I did? I used the XRP braided SS lines and adaptors. Cost me $115.oo, but that was a bargain compared to a new set of hardlines! (Looks better too!)
#108
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Very true, do you have a list of the parts needed? I've never gotten an accurate list of what's needed to do that, and how did you connect to the lines I can't remember, were they threaded in both the rubber lines and the plenum hard lines?
#109
Yes, Russell fittings. There are eight fittings you will need for the hoses, plus about 6 feet of hose. You will remember this replaces the soft black hoses as well. If you call Mike at Lopers performance and mention my name, he will help you and knows exactly what you need. (He has an '88 IROC and did it on his car.)
#110
This fixes the "High rpm pressure drop" problem as well. With the factory stuff my fuel pressure used to drop to 39 PSI (Or so.) when at 4k rpm. now it stays at 60+ PSI at 4k rpm.
#111
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
By the way there is an LT1 intake.. Just intake manifold sitting in a white 94 z28 vert at ecology... Its in the trunk
#112
I SAW A 87-92 WHITE TRANS AM SITTING WITH FLAT TIRES AT THE SOUTH WEST CORNER 35TH AV AND T-BIRD ON THUR NITE. LOOKS LIKE ITS BEEN SITTING AT THE HOUSE FOR A LONG TIME. NO VISIBLE RUST OR DAMAGE JUST NEGLECT. IF I HAD THE KASH I WOULD SNAG IT.
#113
Car: 1989 Trans am GTA
ran into this poor neglected thing last night [IMG] Uploaded with ImageShack.us[/IMG]
#114
LOOKS LIKE A 2ND GEN
#115
#116
Believe it or not, that is an '89 TTA (Turbo Trans Am) He wont sell it, he's the original owner and it has 25,000 miles (Approx.) He even has the stickers! Says they came in the trunk and he never installed them on the doors and sail panels. I offered him 6k about 6 years ago when money was no problem and he just laughed at me. Does not run (Blown motor, he says.) and he even has the original wheels with the original tires!
#117
i might have to go up and check that out. so sad.
#118
NO WAY. IMAGINE IF IT JUST HAS AN ELECTRICAL FAULT SOMEWHERE AND IT RUNS WITH MINOR ATTENTION. MAJOR BUMMER THE OWNER DOESNT CARE SO IT JUST SITS AND WAITS FOR SOMEONE.....THATS HOW I FOUND MY L98. IT WAS SITTING FOREVER..... WAITING.....FOR ME.
#119
#120
He says its a blown motor. The reason he told me for not fixing it is that it is just sitting there getting more valuable...
You mean waiting like a hungry crocodile, or waiting like a virgin bride? There are two kinds of waiting.... I'm just saying....
#121
#122
WHY THAT GUY DOESNT FIX HIS TURBO T/A IS A MYSTERY..... WTF ...??!!
#123
#124
LOL, you have a point, but have you priced a TTA/buick GN block and rotating assembly lately? 5 to 6k easy! (used!)
#125
For that much just build a new one. TA Performance in Scottsdale will sell you everything you need including a nice billet aluminum block for it. And,yes, I know this because I considered doing it once upon a time....
#126
#127
http://phoenix.craigslist.org/evl/cto/2361268805.html
86 305TPI IN AJ. RED ?? AIR INTAKE.
#128
DID 3RD GEN TTA'S COME WITH 231 TURBO V6 ??
#129
http://phoenix.craigslist.org/evl/cto/2364843118.html
ANYBODY LOOKED AT THIS ONE ??
#130
http://phoenix.craigslist.org/cph/cto/2364421567.html
IS THIS WORTH ANYTHING ??
#131
http://phoenix.craigslist.org/evl/cto/2363196214.html
THIS MITE BE WORTH LOOKIN AT.
#132
http://phoenix.craigslist.org/nph/cto/2361102545.html
CHEK THIS OUT SPEED FREAKS....
#134
#135
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Im not sure if this belongs here but anyone looking for cheap LS1 stuff there is an LS1 camaro at the ecology with the motor still in it
#139
just saw this:
http://phoenix.craigslist.org/wvl/pts/2364741258.html
200 for the whole set, could probably go as low as 50 for the seats. i'd offer but tan seats/blue interior... barf
#140
Yep! I took a tour of their facility by the airpark back in '05 when I bought my rear end girdle (Axle blew up anyway,but it wasnt their fault. They make good stuff!) They make both the staggered and stock style block, but as I recall the block is 6k alone... I watched their CNC machine make a set of their staggered heads. Cool!
#141
#142
#144
nice eye! surprised i didnt catch that one. there is an old white car behind the ladies house, i always leave when its dark as hell, so i never get a good look. yesterday i was driving through the back in sunlight, slammed the breaks... i figured it was a chevelle (having not gotten a good look at it, and only see the back end) but yep! second gen camaro! flat tires, rusty fenders, the works.
#145
http://phoenix.craigslist.org/evl/cto/2370103184.html
LOOK AT THIS. A 305 TPI WITH 85 MPH SPEEDO....WTF ???
#146
#147
#148
http://phoenix.craigslist.org/wvl/bar/2370715730.html 86 firebird
http://phoenix.craigslist.org/nph/cto/2343799484.html pretty 92 camaro
#149
anyone have the clips that connect the wheel cap covers to the rims? i dont know what they are called, but i need 2 if you got xtras.
edit... the 2 i have are different. looks like 1 front and 1 rear. so i am looking for 1 of each
#150
Anybody have a pressure valve? Its the 4th line out of the fuel talk. Just need the valve.
