Tucsonan with an OBD1 scanner
Car: 1992 Trans Am Convertible
Transmission: 5 Speed manual
Just wondering if there is anyone on here who has a OBD1 scanner that reads live data who wouldn't mind hooking it up to my Trans AM. I am having so many issues with it and has checked just about everything . However, I have no ses light and come up with no codes. Of course, I would be willing to pay, you would not need to perform any repairs I just need the readings of everything. Any help would be greatly appreciated! Thanks in advance!
Oh, and I can come to you!
Location: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
Re: Tucsonan with an OBD1 scanner
I have one but i won't but i wont be able to help you out tell the 17 of this month. Let me know if you still wont to hook up your TA to my pc.
What is wrong with your car?
Well I'm pretty sure we got it all figured out as of now, thinking a new fuel pump, better wires and plugs, and a new clutch and she should be set! LOL Easier said then done! Hopefully my family loves me enough to buy me car parts for Christmas! LOL! DO you know of a place in Tucson that does tuning?
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
It's easier to do it yourself. Most places around here won't touch OBD-1 tuning, or if they will, they make absolutely no guarantees. Go check out the DIY-Prom board. You only need about $80 of stuff to burn your own chips.
Would you still be able to hook my car up to your pc? I am not getting any codes, however I am still troubled with a hesitation. Very frustrating! Anyway, if so, please let me know when you are available and how much! Thanks!
1 Post
Car: 92 Z28
Engine: Boosted LSX
If I was you I'd download this few programs and do some reading on tuning yourself. Not to hard to learn , etc..
http://www.tunerpro.net/downloadApp.htm
and the deff. files you need here also
http://www.tunerpro.net/downloadBinDefs.htm
$8D/1227730/Super_8dm2.ecu/1227730_8D.ads/90-91 LB9/L98 F-Body
You can monitor almost everything needed. You can datalog , etc....
You will need this cable( i prefer all craigs stuff vs others out there) Or find a cheaper one just search the net for obd1 aldl cable.
http://www.moates.net/aldu1-and-cabl....html?cPath=97
Car: 89 camaro rs
Transmission: th350
I can still scan your car if you want me to, i will IM you my phone number i am back in Tucson now so i can do it any time you want too.
Finally got her running beautifully! I ended up having 3 clogged injectors! Go figure! But, was easily taken care of by Julie at South Bay, had em in the mail and delivered in no time!
Car: 89 camaro rs
Transmission: th350
Are you sure it was clogged? I remember that thing was running rich, where they leaking fuel into the motor?
When we pulled them off the back 3 on the passenger side were def clogged, all the way through, you could see it! And one of those three actually wouldn't hold any pressure, just let all the gas leak out! It's a huge difference now, I was surprised at the significant change. Thanks for all your help again, did you ever get that program figured out?
