Roof rust repair anyone know a good shop for this?
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
I just "discovered" a hack job repair of a rust hole in my 92's roof near the top of the windshield.
Anyone know a good shop that could handle this sort of repair in phoenix? I looked in the sticky's for body shop recommendations, not much there though.
For that matter, anyone have a hard-top roof? I'm going to assume the worst for the moment and say that the whole thing needs replacing.
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Roof rust repair anyone know a good shop for this?
You can call Todd Wills at "wills and sons" at (623) 229-2591. Really good guy and the only body shop I would trust with one of my cars. Good prices too. Hes at Grand ave and olive.
Good luck!
Good luck!
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
I go to east mesa every couple weeks. If I need a whole roof, or just part of one I'd definitely be interested.
How much for it? Where were the cuts made to remove it from the donor car?
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
The cuts are below the actual weld lines and lead so the stock seam is intact. here is my ad from earlier.
https://www.thirdgen.org/forums/sout...me-camaro.html
$50 for a roof
$50 for a roof
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Excellent! I assume the roof area on birds and camaros are identical? I suppose a body shop that knows what they're doing could install it easily...
I could probably pick one up from you some time this weekend if you are available. If not then I suppose next weekend would work too.
Do you also have A-pillars? Not sure I need those but it never hurts to be prepared.
They are identical.
Just tell Todd "Jason told me to call".
Good luck!
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
