headers and emissions
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: headers and emissions
Some people will tell you yes, but the emissions stations are not supposed to pass you if you do not have your complete A.I.R. system intact. The entire system only robs around 1 0r 2 hp. You can modify your headers to include your A.I.R. system: simply weld your original Tubes to the headers.
Good luck!
Good luck!
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
i wasnt concerned with powerloss much. its just that headers with the tubes and a cat with the hookup a far more pricey than those without. plus it looks better under the hood without them. smog pump can be removed with air injection system right? i am definately stil running a cat
You need to keep the pump to pass emissions (Visual inspection) Again, some will tell you that you can get rid of the pump and still pass the visual, but the inspectors are not supposed to pass a car with any of this system removed. I have seen a few headers that look ok with the A.I.R. tubes (SLP and Edelbrock T.E.S. come to mind) If the car isnt your daily driver, you can get Collector insurance and avoid the smog requirements altogether.
Car: 91 rs
Engine: 305tbi
i just prefer the look without air tubes. thanks for your help i am pretty sure i will just leave the smog pump on for the visual. run headers without air tubes. definately have a cat. and if i cant pass with that ill just get collectors insurance. thanks for your help man i really appreciate it
eric
eric
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I running these headers since 2 years now, you really need to know what to look for to see the air tubes on these headers.
http://www.macperformance.com/store/...ategory_ID=566
http://www.cardomain.com/ride/2668586/2
Hotrodboba400
12-10-2019 07:07 PM
redformula88
10-14-2015 06:08 PM
