Need help with your car?
I'm in Phoenix, have been working on birds for a year or so, love them to death. I'm posting in case anyone needs help working on their third gen - I have plenty of free time to spare and am not interested in charging for the service, just here to help out if anyone needs it. Just shoot me a PM.
1 Post
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Need help with your car?
We may have a few projects for you to help with. If anyone needs help, chime in and get the help while you still can.
I am going to be doing a motor swap on the Camaro in the next few months. I could use a hand if you don't mind. Just a little help moving the hoist around. I can do most of it on my own but an extra hand and prospective is always a help.
I am also going to extend an offer to the group here. I like doing diagnostic work, data scans, troubleshooting, motor or tranny swaps, etc. I have a lot of test equipment and heavy arsenal of tools. So if anyone ever needs help do not hesitate to ask. Free of course for all third gens!!
Just out of curiousity, what motor are you putting in it? Bigger TPI? LSX?
We haven't touched the Z yet except to see if it would even crank over. It didn't so now we get to start diagnosing if the engine is seized or just the starter.
Birdtojag - I'm down. Send me some details/contact info/whatever and I'd love to help out.
Burnout88 - I would LOVE to help with an engine swap. PM me with details or whatever so we can make this work
Beater79TA - If you're interested I would love to help troubleshoot the Z.
1. Rodents of some kind ate through several locations on the wiring harness.
2. It might be missing some pieces but it's torn apart enough we just don't know.
3. It hasn't been started in a decade so it might need a complete drivetrain swap.
That and I'm going to be selling it to a friend shortly so it'll be his job to figure out how many new parts it needs before it sees the street again.
Car: '87 IROC (blue)
Transmission: borg warner 5 sp
305/350 engine swap, get spark & gas but the injectors won't open. Have a APYN prom not the right prom ?
Motor # 1
Year One Power Crate 400hp 350 crate engine assembly
Part # CT350PC1
Bascially, its a rebuilt 350 with Ported Vortec Iron heads and LT4 hot cam.
$2989.00
http://www.yearone.com/serverfiles/f...=P26EX8116&trk
For induction I would run a Holley Stealthram setup.
Motor # 2
Scoggin Dickey Fast Burn motor
Part # SDZZ430B
This a GM Fast burn 385 motor with the LT4 hot cam added.
$5698.95
http://www.gmmotors.com/product/SDZZ...ripEngine.aspx
For induction on this motor I would run a TPIS Miniram setup.
Motor # 2 would be an easier install with the Miniram setup, is a new motor with a forged crank and rods, and lightweight almunin fastburn heads. However, as you can see costs alot more.
Both output about the same power so it will be on of these two for sure. Just stuck on which one. I like to use nitrous so I am a little afraid of the cheaper setup.
I could give you hand with that. No problem. Let's hookup one weekend and get it done. It's easier if you come to my place since thats where I have all my tools and test equipment and I would not have pack everything up for a trip but I could come out your way also. Just pm when you want to look at it.
I'm all about power, so I'd go with the second one
Right now I have narrowed it down to two setups and neither are an LSX. I have been saving for years for this and I am about to pull the trigger. One is more of a budget setup and one is more highend. I am just in a mental debate on how much I should spend.
Motor # 1
Part # CT350PC1
$2989.00
Motor # 2
Part # SDZZ430B
$5698.95
Motor # 1
Part # CT350PC1
$2989.00
Motor # 2
Part # SDZZ430B
$5698.95
burnout88: Chris (birdtojag) and I could probably build you the same motor for much less (Option # 2 of course) If you really want the ultimate in tunability, I would recommend a single plane Fuel-injection setup like I am doing, with an accel DFI thruster setup. Very cost effective and with options to upgrade at later dates. Beater79ta is using the Thruster and it seems to be working well. I will be using this system and intake in my twin-turbo T/A.
Just some food for thought. Honestly, if you are contemplating spending that much money, an LSX would be a really good foundation for real horsepower (Affordable, too if you use the LQ9 6.0L truck block and GTO heads.) Either way, we could help you.
For some reason, the lockup wire is showing ground at all times (Locked) so if I plug the connector in, the TC stays locked in all gears. Not sure if the wires has become grounded somewhere or if the problem is in the ecm.
The RS gets dyno tuned with the blower on Friday. Then it's just the cleanup items left on it for extra guages and mounting the hood.
--Jason--
That is still a possible intake since I already own it. I could run the Vortec Base and Superram upper. But's a ***** to install and it is the only thing that had me thinking about other intake setup's. That intake is just so hard to deal with when doing any type of service work on the motor.
just to put it out there im down to help with the cars too, tuesdays and wednesdays im open for anything and i havent done some real fun work in a couple months if anyones interested, whenever soocrispy can get the $ together hes gotta swap a torque converter and i honestly dont feel like squeezing under that car again without a lift so thats a possibility for ya lol
1 Post
He definately needs to get money together. Still has to finish paying me for his engine rebuild.
well we're not in the bronx lol i talked to both chris's today and explained our recent apartment issues with people missing rent and turns out they wanted to send us to court because one of my room mates wasnt paying rent and we owe about 400$ now.... so brennamen is throwing his whole paycheck at it and the one who kept missing only has a small portion to cover, if she doesnt im covering it and shes out, if we cant solve it they take us to court, i have a 4000 lease breaking fee and my credit is screwed... im waiting for money to be straight again so we can get back to building our cars without having to throw down for a dead beat.
On the lighter side of life i got the harness from chris and once i figure out where i can get a dual fan setup and keep the car cool im taking it down for a few days to swap the TPI on, after i put new o rings on that is lol
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
how much would this set up cost? this sounds like it would work great in my 86.
Linson
08-21-2015 02:12 PM
