4th Gen Rear end?
Car: 87 GTA
Re: 4th Gen Rear end?
We could give you the answer, but we'd be doing you a dis-service, by doing that.
If you you'll find that answer has existed long before TGO even did. It has been asked, and answered, well over a thousand times.
Its also a good feeling to know that you can answer your own questions, without having to ask people.
Hopefully you learn, that in a car community, questions are going to be repeated.
This board isn't f'n google.
For future reference, just to **** you off, everytime I have a question, even if it's in a sticky, I'm going to ask it...Maybe in several places...
Car: 87 GTA
You wanna repeat sticky questions...Be my guest. But the TGO Moderators might have a problem with you continuously doing that.
Sorry I tried to help you develop a BRAIN & develop the ability to help yourself. Sorry.... I didn't realize you were totally incapable of finding even the simplest answers for yourself. Maybe you'll find someone here willing to hold your hand & lead you step by step in everything here.
BTW.....The answer that was given to you above? Not entirely correct, so it doesn't help you any.
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Name one thing that isn't direct about the swap.
Panhard Bar
Stocks
Sway Bar
Rear Control Arms
Springs
Torque Arm
Driveshaft
They all fit a 4th gear rear without any modification. I've done the swap personally and it was direct for me. The only thing that requires alittle work is the emergency brake cables.
Jay
Panhard Bar
Stocks
Sway Bar
Rear Control Arms
Springs
Torque Arm
Driveshaft
Jay
Car: 87 GTA
Panhard Bar
Stocks
Sway Bar
Rear Control Arms
Springs
Torque Arm
Driveshaft
Jay
Panhard Bar
Stocks
Sway Bar
Rear Control Arms
Springs
Torque Arm
Driveshaft
Jay
You can BOLT one in, but it ain't finished at that point.
Car: 1991 Z28 Vert
Engine: LT1 350
What about the brakes? Hook your lines up and bleed them. You may need a proportional valve to help balance the pressure between the front and the rear. Not too hard...
The fact is this isn't a hard swap. Very little complication, besides busting those old rusty bolts not a lot is involved.
Jay
Jay
Car: 87 GTA
Jay
Jay
I know WHAT needs to be addressed for everything....I'm not asking because I need to know.
I'm asking to point out issues that weren't addressed.
Car: 1991 Z28 Vert
Engine: LT1 350
Stephen,
Your very persistence. I feel your need to be thorough though.
Anyway,
I enlarged the holes on the emergency brake cable bracket located in the trans tunnel, which allow you to use the 4th gen e-brake cables.
Jay
Anyway,
Jay
Car: 87 GTA
And a stock 3rd gen 16" wheel, on a 4th gen axle, will still fit under the wheel lip & not out past the edge.
hectre13
12-11-2023 08:14 AM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
AkDrifted
08-17-2015 07:45 PM
