surprise,az
#52
1 Post
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: surprise,az
Got an accepted offer on the house i wanted so I should be able to host a wrenching party in about 2 months. Gotta get an electrician out to add some circuits to the garage for lights, my compressor, stereo, TV, AC, and maybe a Kegerator/fridge.
#53
Car: 1991 Z-28
Re: surprise,az
Here is what the guy said about these Heads.. Will ask about compression tonight. "Pair of Complete GM Goodwrench heads with rockers and head bolts , casting number is 14102193 , fits 305 & 350 engines, valves are 1.94" / 1.5" " Will these work for my 305? Please give advice....
#54
1 Post
Car: '91 1LE
Re: surprise,az
Those heads will fit a 305 but... These heads have zero performance potential as they are swirl-port heads designed for a TBI application. Porting them is useless as they will never have the flow necessary for performance/high RPM driving. They are 65cc combustion chambers which means they will lower compression compared to the stock 58cc stock heads for a further performance loss. These heads are good for boat anchors as they are cast iron (52lbs each!) but not much else.
#55
Re: surprise,az
I know an electrician (Fellow thirdgen owner) who works cheap. Let me know when you need him and I will get him over for you. My cars are all MAF. Can you work with that? My combo will be: 1998 vortec 350, Scoggindickie TPI base, LT-1 injectors, etc. Just let me know what I will need to bring to make it work with my car.
91Zrocker; birdtojag can probably help you better with compatibility, but they sound like they will work...
#56
1 Post
Car: '91 1LE
Re: surprise,az
The MAF computers use a different (less memory) chip. The SD ECMs/chips have double the memory of the MAF setup. I don't remember the part # of the blank MAF chips. I know Moates.net sells them but you could probably pick some up in town at an electronics store.
#58
Car: primered 1987 IROC-Z/28
Engine: 305 TPI HO
Axle/Gears: Lotsa slip 3.23
Re: surprise,az
If you need any cable or phone wiring...I can help you out...I work for the Evil *** Communications!
#60
1 Post
Car: '91 1LE
Re: surprise,az
The chip is a specific one made to fit the Moates adapter. When you make your own chips you still have to run the factory PROM for the MEMCAL. The adapter plugs into your ECM and your stock PROM and the programmed chip plug into the adapter. It reads the MEMCAL off of the stock PROM but uses your new chip for the fuel/spark maps. I believe the Tunercat program allows you to tune using a graphic interface similar to LT/LS edit. Its been a while since i've done any of this as I replaced my stock ECM with a Holley Commander 950 so I can tune on-the-fly with my laptop
#61
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
Re: surprise,az
The $60 part from moates comes with one or two of those chips. So we wouldhave allthat we need to get started tuning. It takes a lot of time though. and a dyno would be really nice too.
#62
Car: 92 1LE B4C
Transmission: 4L60
Re: surprise,az
#63
Re: surprise,az
The adapter from moates will work for the maf cars as well and comes with two chips that will work for your car but Idont know anything about tuning maf. i have all the stuff to do it but experience. If you want to meet up some time and start messing with it, I'm down.
#64
1 Post
Car: '91 1LE
Re: surprise,az
moates.net. Let me find my stuff and I will let you know what I have exactly. I also have a cable that plugs into the ALDL and basically acts like an on-the-fly scanner so you can see what the computer is doing while driving.
#65
Re: surprise,az
sfeeney has that too, but for some reason couldnt monitor(Or on-the-fly-scan) my IROC. If I remember right, he said he didnt have the program for 86 cars.... I dont know what all is entailed in this and was thinking about getting into it, but I got really confused reading about it. Plus, I dont think my laptop has enough memory to retain ls1edit, accel DFI and the stuff to burn these chips!! LOL, the IROC is supposed to be my un-complicated car and my wifes toy! LOL, still want to do it though....
#66
Car: 92 1LE B4C
Transmission: 4L60
Re: surprise,az
Everything I have will do a MAF system but I just dont have any know how. If you want to get into it, I'm happy to help all I can.
#69
1 Post
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: surprise,az
We will need to get my engine in my car first. 2 weeks from this weekend is when it should be happening.
#71
Car: 92' White RS C5 wheels
Engine: 350 TBI
Transmission: 6-Speed
Re: surprise,az
Hey I'm in Surprise too. I'm at Litchfield and Greenway. I have a white 92' RS with T-tops. In the middle of body work so I haven't been driving it a ton. I'm down for a get together too. Just let me know when and where.
#73
Re: surprise,az
hey guys i live in waddell basicly suprise is my back yard,just to let you guys know i had to let my 82 g spec camaro go,but i still have my 350 small block built,asking $700.00 obo and i know where a 86 t-top is for sale for 500.00 and it runs.very clean call me if interested at 623-302-0957 name is jared.
#74
Engine: 305 TPI HO
Re: surprise,az
Ok I have now moved back to Surprise...I live just off Reems and Cholla. Got a garage as well...If any of you are around I could use some help with my car...still have the issue with the gauges not working and I got my T5 but haven't cut any holes for the conversion...never done it before and don't wanna screw it up....Any help would be appreciated! Also my wife is deploying to UAE at the end of next month and I want to start tearing my car down and rebuild the 305. Could use a motor stand if someones got a spare hanging around.... Oh and gspec would love to take that 350 off your hands just no cash right now!
#75
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
Re: surprise,az
I used to live in wittman and i've talked to that guy beofre its 305 TBI 5-speed with a cat-back
BADNBLK
Convertibles
65
02-10-2016 03:36 PM
buckeyecelt
09-24-2015 05:50 AM
dbrochard
09-19-2015 08:13 PM
