The; "I NEED...." THREAD. NEED SOMETHING?
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I have been thinking of a way to network, to get the parts we need. Maybe this is the way..... If you need a part that someone in the SW region might have, post it here. This is not a thread for things you have for sale. Start a new thread for that. I'll go first....
I NEED: A parking brake cable for an 86 IROC with 10 bolt disc rear end. Also park brake lever/handle.
Seems simple, let's see if it works...
Car: Red 1984 Z-28
Engine: 4.8 LS
Re: The; "I NEED...." THREAD. NEED SOMETHING?
I NEED: Hood struts and hatch stuts, used or new, just as long as they work. Hopefully cheaper than new! Sick of proping them up with a stick, heh. Thanks
Kyle
Kyle
doc i should have both of those i believe...
and i also have the parking brake handle leather or good plastic
i would recommend going to checker for the brake cable the raybestos they sell fit great and are cheap vs napa or autozone etc that i could not get the supposed cable to work.
I need hrmmm..
long tube headers...
a straight all power drivers and passanger door ....
a cowl hood of somesort
rear disc parts to convert my rear
new main dash not the dashpad.. no cracks in near mint shape.
front nose iroc or rs style not warped no cracks..
electrical work that i dont want to do <--lol
msd wires
T56 or a good t5 rebuild with stout parts
tubular k member
new weather stripping
grant steering wheel
msd wires
tubular k member
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
i need:
91-92 gfx in good condition
Rear disk brake setup in good condition
AIR compatible headers
Heres a longshot..... eaton posi unit for 26spline axles/3.73 gears (too specific maybe?? lol)
and finally somebody with a welder that can weld my i-pipe up (properly) in a few weeks
Ok, this seems to be working...
master_disaster; 92whitez28 has some of the 91-92 gfx you want. He has rear cover, rear quarter extensions both door filler panels,and drivers side rocker panel. PM him and let him know you are interested.....
sfeeney; 92whitez28 might have the main dash you need... I didnt think checker sold them for the disc rear... I will check it out. Thanks!!
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
well i already got the cluster, gas door and exhaust off that iroc hes parting out i took a look at the gfx and the passenger side is all busted plus if i remember someone already showed interest in the chin spoiler, if the passenger side wasnt destroyed i would have taken those too lol im just trying to get it all in one complete set
i do like the idea of this thread way to go
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 9 Bolt Cover
unfortunately i say toss the 9 bolt, theyre nice but parts for them are harder than hell to find, 10 bolts have more readily available parts at alot nicer prices
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
I have long tube headers taking up space in my garage they're headman headers
Thanks, master_disaster. I got the 91-92 gfx for my RS from about 4 different cars. It is really hard to find all of the pieces on one car. I would take the parts he has and then you just need the chin and high rise. The chin is the hardest piece to find.
Thanks!
Thanks!
Ok Mario i want those long tubes for sure....
as long as they are in decent shape.. what size collectors are they
I have a 10 bolt posi at my place if you ditch the 9 bolt
If not there is a 9 bolt on a blue and gray firebird transam at pull a part on 27th ave and lincoln that you could get parts from for your 9 bolt
If that dash is near mint not cracked or warped and still looking good im down...
Car: 1989 Firebird Formula 350
Engine: 5.7l
Transmission: 700r4 New Rebuilt 2011
Axle/Gears: 9 Bolt
How about a 9 Bolt Diff cover?? Anyone have luck with getting past emissions? The previous owner removed the Air injection tubes, Cat, and Diverter valve. I have gotten the diverter valve and cat fixed but I do not have the air injection system on. Any suggestions.
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
I am still looking for a dual snorkle filter assembly?..and a camaro or iroc grill?.I replied about that car your parting out and dont know if you have them still or not?still interested..I am also looking for a fiberglass hood (no flat ones)something with a cowl or other...pin or bolt on dont care.And lastly I need a women who likes to spend money on car parts..ANyOne????..
azfirebird, what engine do you have, what year and what parts do you need?
As for a woman who loves to spend money on car parts, I have one. (But I'm keeping her, Married her to make sure she dosent get away) I'll let you know if I find another one.....
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
hey sean do you know what posi and gears are in there? the one i picked up has an eaton grenadelock in it lol hows the brake setup lookin on that cuz if its better than mine i may just have to take it off your hands instead of buying new calipers for this one
i have an electric trunk pop with alot of wiring..
i also posted i have a complete 10 bolt posi or
there is a blue firebird at the pull a part junkyard on 27th and lincoln with a 9 bolt rear end in it. you could get parts from it
Engine: 5.7l
Axle/Gears: 9 Bolt
Thank you for this I would be interested in the electric lock what are you asking for it?
OK, My turn... I need a set of trans-am crosslace wheels (16") With or without tires, is ok....
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I need a lower center console a Camaro with no cracks, holes drilled in, sun faded and the radio mounting tabs not broken off. Also need one that does not have carpet glued to it.
I know I am dreaming about this. As from what I can tell a part like this does not exist in used condition.
I would say you should be able to find that. (might not be able to get it without the carpet, but hey, you can ask!!)
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
I have a 700R4 with the electronic speedometer and electronic lock up comes with torque converter also includes new transmission mount and cross member. slips on first i believe its a 26 spline open to offers will fit Chevy truck camaros firebirds trans ams
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
AZfirebird, I have the 9-bolt cover. Where are you located and stuff? PM me your number and I'll get back to you as soon as I can.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
well i have my flowmaster i have to install if he wants my stock one that'd work lol just have to get a welder so i can install it
I need a RED 85-90 trans-am bumper cover. (Front) Also front fender extensions to match.
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Just met a guy at the carwash, he just bought an LO3 RS..Needs a Radiator and front grille...I told him I'd see if I could find him one..
Car: A Camaro
Engine: Weak
Transmission: Weaker
Originally Posted by azfirebird
350 5.7L I need diff cover and trunk electric latch system to include wiring and bracket.
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
I need a center console door, Black for a 85-92 Thirdgen
Art
I also need a wiring diagram for the rear hatch lock and courtesy light system
for same car, keep popping 20amp fuse for courtesy lights when i try to open rear hatch and it doesn't open. closes fine.
Art
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Heres a link to Autozones site, they have all the wiring diagrams online just choose the one that fits your application, should be under body wiring/ body continued if i remember correctly.
Keep in mind that your courtesy lights, cigar lighter, and hatch plus a few others are all tied into that circuit. Should all have orange wires running to them denoting the Acc. Fuse, the 20 amp you keep blowing. Id check your cigar lighter, mine kept blowing the fuse when i hit a good bump the side would short out. I just took it out and pulled it apart, cleaned it up and put it back, works fine now
Hope this helps
#42
Car: 87 GTA
Engine: 5.0 LB9
Transmission: 700-r
Im not in need right now just wanted you to know i am watching this thread wait does new mexico count as we dont seem too be one of the 50 states hahhaa
Rail
Rail
#43
Arvizu, do you men for a firebird or camaro? I have a few from a firebird but none from a camaro.
#44
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Well, let's see here....
I need a passenger side AIR tube for a 88-92 305/350
I need a front bumper cover for an IROC
I need an IROC hood, with or without louvers, no damage.
I need T-Top weatherstripping.
I need someone who knows how to align the windows inside of the doors.
I need a set of t-top sunshades, factory preferred.
I need the little pieces of trim that clip over the ends of the shocks in the hatch in black.
I need someone who has an idea of how to align the trunk panels, one of mine dips in and drives me nuts.
I need someone who is decent with seam sealer, because some of my seams had mold in them, and I scraped them out and no longer trust myself to finish the job.
I need a hood pop latch assembly.
I need a driver's side underdash panel, with or without the fuse panel piece.
I could use a console lid in better condition than my own.
I need someone local who wouldn't mind showing a newb the ways of sanding priming and other paint prep. :3
Uhm. I think that's it. Probably not.
#45
Car: `86 SS / `87 SS
I need a 153 tooth manual SBC (85-down or 86-up) flywheel. If it's new and you're not using it, I'll borrow or consider buying from you. If it's used and can't be turned anymore or has chipped teeth, I still need it. It's for mockup purposes only.
#46
Car: 89 DROPTOP RS AND 99 CUSTOM LAC
Engine: 383 TBI
Transmission: B&M 700R4 STAGE 2
Axle/Gears: 373
I NEED THE CABLE THAT CONTROLES MY DRIVER SIDE MIRROR AND I WANT A SS HOOD FOR MY 89 CONVERTABLE
#48
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Second, ^ hes right, sfeeny is the go to guy for parts, i get most of my stuff from him because hes constantly parting cars, chances are hes got the parts youll need,, always good prices too.
Not to mention between all the members on the SW boards, there is a wealth of information on parts and whos got what, i just wish sfeeny would post up that contacts list lol, send him your info and hell add you
#49
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I need a front bumper cover for my IROC.
I have some body parts to trade or sell cheap!!
#50
Car: 1989 IROC
Engine: 305TPI
[quote=sfeeney;3856983].
[quote]
I have a nice power ps door
[quote]
