South West Region South West regional discussion board.
Wanted to buy: Gas cylinders
Old 10-06-2004 | 12:58 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Anyone around here got an argon, oxygen, or acetylene (or all three) cylinder they want to get rid of?
Old 10-06-2004 | 01:01 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
OH my G0D!!!
Your want to buy a torch, what are you up too now?
Synapsis's Avatar
Car: Sexy
Engine: Stock
I bought a TIG welder and a gas setup. I need cylinders. :P
Old 10-06-2004 | 01:06 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
So you going to crate your own monster garage?
Old 10-06-2004 | 01:08 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I'm going to turn my Iroc into a lobster.
The tube chassis for the VW comes completely welded for 2995$, or as a kit for around 1100$. If I buy the kit and a welder, it's still cheaper than having them do it, and I get to keep the welder.
Plus I might get bored and make some V8 turbo headers.
Old 10-06-2004 | 01:10 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
Monster Hellica!
Old 10-06-2004 | 01:11 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
V8 turbo headers shouds like fun.
Old 10-06-2004 | 01:15 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
you make some turbo header and I think I might just buy them off u. make sure there extra booger welded.
Old 10-06-2004 | 01:17 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
I have never seen synapsis weld but I am sure that booger would be the expression.
BOOST BY BOOOOOGER
Synapsis's Avatar
Car: Sexy
Engine: Stock
It's pretty hard to booger TIG since you add the metal to the pool. I'll do your set with some 6013 SMAW rod to get the proper boogerage.
Old 10-06-2004 | 01:19 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
BOOST BY BOOOOOGER
I've actually taken a couple semesters of welding. I can't do MIG, and I'm sketchy on aluminum still (but I'm taking lessons now.)
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
eeeexxxxxxcellent :hail:
but seriously though, if i keep this car it wll be turboed. It must be turboed.
Old 10-06-2004 | 01:21 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
So are all the thurdgens in tucson going to be turbo now?
Old 10-06-2004 | 01:22 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
If I hand-make headers, you guys couldn't afford em. :P
Old 10-06-2004 | 01:23 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
No, just mine. your will be supercharged, Synapsis will be nitrous powered.
I can proudly say I've become a boost *****, sprinkle me.
Old 10-06-2004 | 01:24 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
I think you have been sprinkled with some faget dust.
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
When I say turbo header I mean take a real header, cut off the pipes 3 or so inches from where it bolts to the motor, and weld on a 3" pipe to the header piece, then an adaptor to bolt the turbo onto the 3" pipe, boom..Turbo header. No modifying need to be done to the drivers side header, just a run a pipe to connect it to the pass. turbo header for a single turbo app. or make 2 turbo headers for a twin setup.
Old 10-06-2004 | 01:25 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Hey, I'm not limiting myself to just nitrous.
Old 10-06-2004 | 01:26 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
I think if you where to actualy make a turbo kit that i would want to put on one of my cars, I would end up doing a hole buch of grunt work to one of your cars in exchange(fuel pump on fbody).
Synapsis's Avatar
Car: Sexy
Engine: Stock
Edit: Nevermind I thought it was something else.
I'm talking about making a header from scratch so I can put the turbo in a place to keep all the belt driven items in their normal place.
Old 10-06-2004 | 01:27 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Fuel pump's already done, homey. How are those slicks I paid you with workin out?
Old 10-06-2004 | 01:29 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
The puep was an example, The slicks are not doing so good but the rims are in ok shape.
Old 10-06-2004 | 01:30 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
The thing is... I have a garage now. And the fuel pump is the #1 ****tiest job to do on a thirdgen anyway.
Old 10-06-2004 | 01:32 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
yeap, and thats why i got stuck doing it.
So how are those lca brackets doing. You make those new ones yet?
Synapsis's Avatar
Car: Sexy
Engine: Stock
If you buy the headers and flanges, I can weld em for a small fee.
Old 10-06-2004 | 01:33 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Now that I have a welder, those are #2 on the list of stuff to make. After building a steel welding table. I'm going to make the lift bars out of chromoly this time. They'll be the pimp shizzle.
Old 10-06-2004 | 01:35 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
make that #2and #3 I want to buy the same set of lca's as you have but I am not sure about those alcb. I don't want them to end up like yours did.
Old 10-06-2004 | 01:37 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I'll make them for a small fee.
I'll tell you now, the chromoly tubing and heim joints that size aren't cheap.
Old 10-06-2004 | 01:40 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
small fee!? what ever happened to doing it for the sake of getting to cut some shizzle up and weldin it together.
Old 10-06-2004 | 01:41 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
TIG has 4 consumables. Gas, welding rod, tungsten, and electricity. None of which are free.
Old 10-06-2004 | 01:43 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
sergio sergio sergio, always trying to get something for nothing:nono:
Old 10-06-2004 | 01:47 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
blah, thats cool.
Old 10-06-2004 | 01:49 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Gotta give him credit for trying.
1500 posts... w00t
Old 10-06-2004 | 01:51 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
JUST PLAY'N DOGG, DON'T HATE ON A BRATHA
Old 10-06-2004 | 02:09 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
You guys and your turbo/supercharger fantasies. Its like listening to little kids talk about getting Ferraries when they grow up.....nice thoughts, but just ain't never gonna happen . Now me on the other hand, I have a car I can actually supercharge for well under a grand........
Old 10-06-2004 | 02:12 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
*points to the twin turbo motor in the garage*
Making my own turbo headers only costs me a little bit in materials and a lot of time. After that you can get turbos off ebay for cheap. Then it's 500-600 throwing-rods-out-the-block horsepower. (Pssst, what do you think I have the spare 350 for?)
Old 10-06-2004 | 02:13 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Oh yeah I forgot....
How long have you been talking about supercharging that thing?
Do it! Dammit.
Old 10-06-2004 | 02:18 PM
Car: Junk
Do it! Dammit.
Getting the right mods done to it first. I don't want it to be like that mustang I raced in front of coach's in my firebird that had a stock 5.0 motor with a blower, and I was still beating him. I still need to put an intake manifold on, and get a 77mm MAF with matching 24 pound injectors, and a MSD BTM 6 boost ignition, then it should be ready for about 10-12 pounds of Vortec V-1 thirdgen smoking power
Old 10-06-2004 | 02:23 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Ok, so I'll drive your firebird against your Mustang after you get all this done.
Old 10-06-2004 | 02:26 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
U need to stop runnin yo mouth and buy the damn thing already.
Al some people ca do is talk and dream, some people dont get there rent paid by there sister and have thier GF pay the bills so they can spend there whole check on whatever they want .
Old 10-06-2004 | 06:31 PM
90_WS6_Formula's Avatar
Car: 91 Z28
Synapsis:
Make sure that any bottle you buy isn't too far out of certification. They might raise a little fuss when you go to have them filled if they are.
MIG welding is easy. A lot easier than TIG and only a little more complicated than stick.
Contract your gasses from a supplier and you'll get them cheaper.
and LMMFAO@Mike with the dust comment!!!!
Old 10-06-2004 | 06:49 PM
  #42
Synapsis's Avatar
Car: Sexy
Engine: Stock
I just don't like the wire feed. It's either too fast or too slow... you have to start the arc and get moving or else it goobers... TIG you can take your time, makes nice clean welds and stick is just cake.
I already got a price on the Argon bottle from Pima Welding Supply.. just wanted to see if someone has a bottle they didn't need anymore for cheap.
Old 10-06-2004 | 07:20 PM
  #43
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
blah blah blah
your on that same bandwagon, every time i talk to you you are telling about some super turbo charger blower power you are going to put on your mustang some day when the rest of the world stops taking money out of you pocket.
Old 10-06-2004 | 07:26 PM
  #44
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
The 5.0 wasn't a black LX Hatch was it? With plates that say 5.SLOW?
My buddy Cody has a supercharged 5.0 thats basically stock except for the blower...The cars now sitting my buddies backyard with the motor pulled.
Old 10-07-2004 | 04:00 PM
  #45
Car: Junk
Remind me again.....who pays your rent? Who makes/buys your dinner? ect..ect.. Rent is not the ONLY bill when you have a house, not an apartment, there is things like gas, water, electric, food, ect..
BTW, my sister is not just "paying my rent", I'm working for it. I babysit for her 3 days a week, and $500 a month is the same she paid her last babysitter. If you don't think taking care of two toddlers 3 days a week 12 hours a day is a job, then you need a head check.
Old 10-07-2004 | 04:02 PM
  #46
Car: 91 Z28
you should look into getting a raise, Chris
Old 10-07-2004 | 04:03 PM
  #47
Car: Junk
Yep, black LX hatch with red pin striping and a blower. I raced him a couple times late at night in front of Coachs and blew him away pretty bad, 5-6 car lengths with my firebird N/A. Hope he gets it running better, he's putting supercharged mustangs to shame. When I put my blower on my stang it better whoop up on my firebird motor versus blower.
Old 10-07-2004 | 04:05 PM
  #48
Synapsis's Avatar
Car: Sexy
Engine: Stock
Especially her kids.
Since we're off topic anyway, my welder is sitting on the dock here at work. I'm going to go dry hump it now.
Old 10-07-2004 | 08:17 PM
  #49
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Haha, yea its nothing too special...Just a basically stock 5.0 with a blower and crappy street tires. If he got some sticky tires, that would help a ton.
Old 10-08-2004 | 06:58 PM
  #50
Synapsis's Avatar
Car: Sexy
Engine: Stock
Happy (insert holiday here) to me!
:hail:
Quick Reply: Wanted to buy: Gas cylinders
