Ramjet 350
Car: 88 gta
Engine: 383 tpi
Axle/Gears: 342 10 bolt
Ramjet 350
Has anybody swapped a 350 ramjet with L98? Considering an engine swap into 1988 GTA-seems like a lot of engine for 4500.00, not sure if if their is hood clearance with stock hood. Have TH700r4 want to use. Appreciate any comments.
Engine: None
Transmission: None
My buddy nate back home swapped a ramjet into his 82 Z. Looked great and ran like it also. You'll have plenty of hood clearance. heres a pic. he went kind of crazy with the wire loom though.
Car: 88 gta
Engine: 383 tpi
Thanks for the pics, looks like an easy swap. Do you know if the car can pass emissions? I know GM does not claim to have tested for that. Also looks as if all accessories bolted up in the picture.
The ramjet pulls up to 5200rpm? the L98 in car now is done at 4500, but it sure has a lot of low end torque.
Car: Sexy
Engine: Stock
Transmission: Slipping
Engine: None
Transmission: None
Yeah everything bolts up. He had to custom make a throttle cable because they dont make one specifically for that car. LEast I don't think. Also no it does not pass emissions. He had to unplug the 6 and 8th injector to make it run lean so it would pass. pretty weird but it works.
Car: 88 gta
Engine: 383 tpi
Originally posted by Synapsis
Swap out the TPI and the cam on an L98 and it'll put a lot higher.
Car: 88 gta
Engine: 383 tpi
Car: Sexy
Engine: Stock
thanks for reply. bought the car new in 1988 and it sat for 6 years or so, now got it running, and painted it-now I want more power. Have 135000 miles, runs pretty strong still, everything works, so many options, not sure if I should build the L98, or look for crate motor. Don't want to spend a lot
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Yeah, especially if it sat for 6 years!! You may have it running now, but unless that thing got started AT LEAST once a month no telling when something may decide to commit suicide. Plus, it just sounds way more impressive to tell people you have a crate engine!
Sweet-A$$ looking car though! Really sharp!
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
i would love to take that tired l98 block and heads off your hands also..
so yeah go with the crate motor and let me know when your selling the engine and heads :-D
Shawn
Shawn
Car: 86 IROC-Z
Engine: 406
*didnt read whole thread* but. GET THAT AIR FILTER OFF THAT ENGINE!!! and put a CAI kit on it.. all u r doign is sucking in HoT air and killing that engine..
Car: 88 gta
Engine: 383 tpi
So instead of going with the Ramjet i built a 383 with LTR and all the smog stuff. Haven't done a chip, and running street tires i ran 13.5@104mph, best 60 was 2.62
think i will put some bf goodrich drag radials on it, if i can get a better 60 i should get 12's. seems it doesn't hook up untill 3rd gear-hitting something like 115 in the traps.
here is a video http://www.raichert.com/transam/1988gta1.htm
So what you got packed in your 383?
We are going to the track on FRI if you want to join us.
FYI...These just came out, might wanna think twice before buying BFG drag radials.
http://www.mickeythompsontires.com/s...et_radial.html
Car: 88 gta
Engine: 383 tpi
Here is what i running
383-Edelbrock LTR-Aluminum Eldelbrock heads 2050 int ported-comp cams XR276, 11:1 comp, ported intake, 1-5/8 hooker super comp headers, flow master cat back, msd 6al 24lb injectors
i have a few pictures of the engine on the above link, also a video on my first time out at speedworld
Where are you guys going on Friday?
Thanks i will check out the link, do you not like the BFG'S?
Car: 88 gta
Engine: 383 tpi
sorry, i fixed it in first post should be http://www.raichert.com/transam/1988gta1.htm
not the best quality, but you see i had to walk it out there with street tires, comes on strong at the end.
Linky no worky.
Linky no worky.
We are going to Firebird.
The coating on the heads is sweet, what heads are they?
Aslo, what codec for the video? It wont run for me.
Car: 88 gta
Engine: 383 tpi
coating helps it run cooler, also have coatings on piston skirts, and coating on the intake that is suppose to cool air. The heads are edelbrock with biggest valve i could get, there is only .0030 space between them- ported and flowed.
the video is an avi file, it runs off my windows meadia player. maybe i will compress it
how busy is a friday at firebird?
I know all about coating, where did you get it done and for how much?
Also, what Edelbrock heads are those, they sure look differnet than anything I have ever seen from Edlebrock, they look like TFS twisted wedge or Pro Topline combustion chambers.
Car: 88 gta
Engine: 383 tpi
heads are #60859 not sure what style-coatings were done by Mach Development-Bud Yancer-39th ave & Indian school
-paid about $320.00 for coatings
That video is perdy kewl, that car sounds mean man! As for Firebird, I went friday before last and it was PACKED, but I sill got 4 runs in! There were some sweet as #^Q&# cars there... (broke back into 15's on stock LO3!! woohoo!! )
Bruce (90RS305)
Bruce (90RS305)
