South East Region Regional Board for South East Members.
Official Tampa, FL Area Thread
Old 08-03-2015, 08:04 AM
  #1801
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Official Tampa, FL Area Thread
Old 08-03-2015, 08:37 AM
  #1802
TGO - 10 Year Member
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Originally Posted by redneckjoe
i've used the aresol spray on bedliner from duplicolor with good results on small parts. like an aluminum plate i fabbed after putting a b&m shifter in. the texture is very close to the original plastics. after fixing my cracked dash i sprayed it a few times too. most people wouldnt even know. sure cant give a recommendation on the floor. i think heat would be the biggest enemy? i have no carpet in my car and i can tell you the floor gets very hot after driving it a bit. floor mats help though.
is it ever gonna stop raining? geez.
Right? I wish my wipers worked correctly and my roof didn't leak lol.
Old 08-03-2015, 09:15 AM
  #1803
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Tell me about it... I arrived to my car at my new house with a huge pool of water in the backseat area, lol
Old 08-03-2015, 09:53 AM
  #1804
Car: 1989 Camaro RS
Engine: LH6
Sounds like my car! No need to go to Disney or anything when I have a water park in my car.
Old 08-03-2015, 10:31 AM
  #1805
Shrike's Avatar
Hello, Any bay area guys have a front wheel drive 60V6?? I need a FWD timing cover and balancer. Also ISO 60V6 headers.
Thanks ! !
Old 08-03-2015, 02:39 PM
  #1806
Car: 1989 Camaro RS
Engine: LH6
Anybody have a T5 or know where one is? I want to swap my car pretty quickly.
Old 08-03-2015, 03:52 PM
  #1807
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
It stopped raining. Well, till tomorrow anyway.
Old 08-03-2015, 07:01 PM
  #1808
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
every time i see a 5-speed donor car for sale cheap, i never have the cash. damn curse!
no way i can get my camaro out of here. i live on dirt roads and getting the truck out of here is tricky. my t-tops leak too, just a little bit. when i pulled my carpet i drilled a couple 1/8" weep holes to let water out.
oh, and my tranns leaks too. i know its the dipstick though. the o-ring didnt seat in right.
Old 08-04-2015, 07:25 PM
  #1809
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Finally found a nice vortec 350. Used a borescope before getting it to look into the intake valley and a few cylinder walls. Still has the crosshatching after 120k. Heads and intake valley were spotless. I plan on putting some heads on I got from a buddy, they had less than 1000 miles but sat uncovered in storage and got some surface rust on them. I think him blowing a head gasket also contributed to it. Anyway can I clean these without wasting money at a shop?
Old 08-06-2015, 12:34 PM
  #1810
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
So here's what it looks like with the floorboards painted with black bedliner.
I still gotta put the drain plugs back in, and do some other tidy up stuff, but I think it looks miles better than rust stained carpet.
Old 08-06-2015, 12:44 PM
  #1811
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Looking good. Nice to know that your floors won't get rusty from any water getting in. I need to put something like bedliner on the bottom of my car. I found some surface rust on the welds because I did a shitty job at painting to prevent it.
Old 08-06-2015, 05:22 PM
  #1812
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
I did have some surface rust from the heater core blowing up on the PO. But nothing major. Spent the last few days sanding, and sanding and painting and sanding. But, it is waterproof, and hopefully will keep back the rust. If not, I can do it again. I think eventually I'll do the whole interior, but that will take 3-4 more cans, and removing seats, blah blah blah.
Old 08-07-2015, 05:30 AM
  #1813
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
looks good from here. i just used some cheap black spray paint, then put some black floor mats in there. probably look nicer if you pull the seats and do it all?
finally changed my front coil springs. it was going good, then,...let me cut another 1/2 a coil,...Ooops, too much. it looks stupid low in the front now. kinda mad about it.
Old 08-07-2015, 06:12 PM
  #1814
L98GTA87's Avatar
Car: 1987 Trans am
Anybody interested in a set of 906 vortec heads?
Old 08-17-2015, 03:06 PM
  #1815
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
So this is as far as I am going with the interior for now. I had some Duplicolor vinyl spray stuff sitting around, and on my mission to get rid of the beige interior, I went to town on the door panels. I could probably use another can, I ended up using two to do both, and there is still a little inconsistency. But, it is a start. I also (finally) installed the other Blazer seat in the passenger side so that 1-I could get rid of the last nasty old camaro seat and 2-I was afraid the rat in the garage would get a hold of it. Now I have the seat covers off, to show the clean seats. I know, I know, the driver's side says "Blazer" on it, and they are grey with red trim, but they are 90% stain free, and feel a million times more comfortable.
Old 08-17-2015, 06:09 PM
  #1816
Car: 1989 Camaro RS
Engine: LH6
Looks nice dude!
Old 08-17-2015, 09:09 PM
  #1817
Car: 1991 Firebird
Engine: 3.1L V6
I cleaned up some mold that started to grow in my car. That's what I get for not driving it.
Old 08-18-2015, 07:42 AM
  #1818
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
looks good from here!
i've been slowly stealing odds & ends off the parts car here. black arm rests, window sweeps, plastics, screws, etc. nothing real exciting. fixed my trans fluid leak finally, lol. since i cut my trick springs a bit too short, i cut up some old motorcycle fork springs & made my own helper/coil over struts, lmao, but it worked. i'll have to get pics. it looks clean & the front end moves up nice. still in need of tires badly.
Old 08-18-2015, 09:24 AM
  #1819
Car: 1989 Camaro RS
Engine: LH6
All you guys working on your cars, I drove mine for the first time in a week and a half today lol. I sold my IROCs to Will, and I need wheels ASAP. If somebody has C4 Vette wheels or GTA wheels for the low I'll take them.
Old 08-18-2015, 01:31 PM
  #1820
Car: 1991 Firebird
Engine: 3.1L V6
I haven't driven mine in almost 2 months.
Old 08-18-2015, 01:36 PM
  #1821
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
Mine is my only car, so I don't have much choice, she gets driven.
Old 08-18-2015, 05:04 PM
  #1822
Car: 1989 Camaro RS
Engine: LH6
Mine used to be my only car, so glad it's not that way anymore.
Old 08-19-2015, 07:10 AM
  #1823
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i remember when i had a 78 camaro as my only daily driver. went to work in it, raced every sunday, had no back seats so i could fit all 4 kids in it, got groceries, etc. a true street car. pulled many all-nighters to get to work the next day.
anybody got any cheap 15" wheels? i need 2 for the rear as im switching from 16's. i dont care what shape theyre in, or if for a bird.
Old 08-19-2015, 08:38 PM
  #1824
DevilInside's Avatar
Car: 1987 Pontiac Trans Am
Engine: 305cu. 4BBL
Transmission: 5 speed manual
Hey all. Any ideas on how to prevent vapor locking? Im having major issues with it on drive home. Its a LG4 with edelbrock 1406. Mechanical pump. Thanks in advance.
Old 08-20-2015, 10:11 AM
  #1825
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
If your boiling the fuel, do you know where its getting hot at?
are you running steel lines or hose? route all your lines away from heat sources. or wrap them.
or a spacer at the carb if it getting hot there.
what is your fuel pressure set at? if I remember right, edelbrock carbs only like 5.5 lbs.
are you running a return line to the tank?
Old 08-20-2015, 11:40 AM
  #1826
Engine: 305cu. 4BBL
Running between 5-5.5 psi. Yes it has the original return line. Most of the lines are steel with some rubber here and there. Last I checked the carb is getting very hot and if you feel the lines they hot to the touch. Also when I remove the gas cap it does that pshh sound. I had cleaned the vent valve a while back.
Old 08-20-2015, 12:39 PM
  #1827
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
id go with the cheap and easy route first. wrap the steel lines or move them to keep them from heat soaking.
what manifold are you using?--enough room for a spacer?
Is the muffler under the tank? is the heat shield still there?
how hot is the tank getting?
Old 08-20-2015, 07:39 PM
  #1828
Engine: 305cu. 4BBL
The manifold is stock all it has is the spacer to convert from Quadrajet manifold to Edelbrock carb. But the hood is raised a couple inches in the back so i should have room. Was also thinking maybe one of those thermal gaskets from Jegs.com or Summit. Original exhaust system rusted and fell. I have a glasspack where the cat would be and nothing else.
Old 08-21-2015, 11:53 AM
  #1829
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
insulate the fuel line first, before you spend the dough. if it works then you can get the good stuff.
heres a little food for thought
Attached Thumbnails Official Tampa, FL Area Thread-cork-002.jpg   Official Tampa, FL Area Thread-389943084.jpg
Old 08-21-2015, 05:27 PM
  #1830
Engine: 305cu. 4BBL
Cool thanks. I'll look into it on either reroute them or insulate.
Old 08-21-2015, 09:32 PM
  #1831
L98GTA87's Avatar
Car: 1987 Trans am
This will be going in my GTA soon. Vortec HSR.
Old 08-21-2015, 10:08 PM
  #1832
Car: 1989 Camaro RS
Engine: LH6
Sweeet! I saw you bought a HSR in the classified.
Old 08-22-2015, 08:57 AM
  #1833
Engine: 305cu. 4BBL
Very nice!
Old 08-22-2015, 09:14 AM
  #1834
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
looking good! what kind of timing cover is that?
Old 08-22-2015, 09:20 AM
  #1835
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
IDK if you should be getting the "psssh" sound when taking the gas cap loose? i run a carb and vented cap.
i cut up some soda cans, flatten them out into sheets, then wrap them around the steel fuel lines and gently tighten with a hose clamp as heat shields.
the plastic wire covering can help too if its not too close to heat.
doubling up on the mechanical fuel pump gasket might help too?
next time your intake is off, use heat cross-over block offs.
a phenolic or wood carb spacer will help.
i've never tried the clothes pins but people swear it works.
Old 08-22-2015, 11:16 AM
  #1836
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
My car apparently had vapor lock issues when it was produced because there was a recall to fix it. Dealerships put low psi electric pumps in the tank as well as leaving the mechanical pump on the block and it apparently fixed the issue.
Old 08-22-2015, 04:35 PM
  #1837
L98GTA87's Avatar
Car: 1987 Trans am
Thanks! The cover is just the stock vortec 350 cover. Plastic and has some nice features but some say it's leaky. Guess I'll find out. I was gonna sell the vortec heads and use some crappy heads but figured it'd be best to hold on to the heads and go with the stealth ram. I got super lucky on the intake so grabbed it quick and had the heads completely rebuilt. I started it up on the stand today. She's ready.
Old 08-23-2015, 05:57 PM
  #1838
Car: 1989 Camaro RS
Engine: LH6
Old 08-23-2015, 07:17 PM
  #1839
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
oh no, Ducky is up to something...
You finally doing the t5 swap?
Or are ya fixing that exhaust that may or may not be too low for comfort?
Old 08-23-2015, 08:56 PM
  #1840
Car: 1989 Camaro RS
Engine: LH6
Put 1" spacers on the wheels.
Old 08-23-2015, 10:30 PM
  #1841
Engine: 305cu. 4BBL
Heres a thought. Would thermal tape or header wrap work to insulate the lines? I might have some laying around.
Btw. I love the stance of that Camaro. Probably a bit tooo low for my driving lol, but looks great!
Old 08-24-2015, 12:17 PM
  #1842
Car: 1989 Camaro RS
Engine: LH6
It's super low, I have maybe 1/4" from the bottom of the air dam to the ground, same with the exhaust. I hit road reflectors all the time. I'm gonna go lower but I need different wheels/tires and I have to roll the fenders. But that's after I repair my motor.
Header wrap might work, I haven't experience fuel boiling since I went to braided lines, but that gets expensive.
Old 08-24-2015, 12:20 PM
  #1843
Car: 1989 Camaro RS
Engine: LH6
I'd be interested in the TPI intake and stuff if you are planning on selling it.
Old 08-24-2015, 05:26 PM
  #1844
Car: 1989 Camaro RS
Engine: LH6
Oh, if anybody knows somebody selling wheels that will fit our cars for cheap let me know. I need something to roll around on.
Old 08-24-2015, 08:15 PM
  #1845
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
...I got s10 wheels real cheap...
Old 08-24-2015, 08:42 PM
  #1846
Car: 1989 Camaro RS
Engine: LH6
I ended up getting C4 sawblades for $150.
Old 08-25-2015, 12:21 AM
  #1847
84LsxZ28's Avatar
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Oh cool, I always wanted to see how those would look on a low thirdgen.
I also wasn't serious about the s10 wheels, no one wants them
Old 08-25-2015, 11:18 AM
  #1848
Car: 1989 Camaro RS
Engine: LH6
Lol, I would have taken them if they had tires. I have to find a used set of 40 series 17s for these wheels.
Old 08-25-2015, 06:20 PM
  #1849
Engine: 305cu. 4BBL
Heres two pics of my problem lol.
I think they are a bit to close to the manifold, I wonder if this is the culprit (PO put them there)
And this is how my filter looks after 20 mins of driving....no fuel what so ever....that filter is not even a month old either...
Old 08-26-2015, 12:03 PM
  #1850
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
do you have the fuel pump in the tank still? if so, pick one. mechanical or electric and remove the other
those lines really aren't that close.
imho, if it was me. Id drop the tank, clean it out. put a new electric pump in, and yank the mechanical. and put the stock style fuel filter back in.
Quick Reply: Official Tampa, FL Area Thread
