Official Tampa, FL Area Thread
#1101
Re: Official Tampa, FL Area Thread
Unexpected event today, bought an Ls1 intake. Fully ported, ported throttle body, and it has 60Lb injectors with new fuel line and fuel rails. Decided that this would be cheaper than going with the Holley carb intakes with the MSD ignition boxes, and would also match better with the cam kit I'm getting. Need to finish porting my heads and match the intakes ports to the heads intake ports.
I'm also picking up coil packs with the harnesses and msd plug wires tomorrow. CL has some pretty good deals sometimes
#1102
1 Post
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Well 99.8% done. Trans still needs to be pulled for the tailshaft, vette servo, pan and boost valves.
While the car is up Ill do the motor mounts, and put the drop springs in. I might wait on the rear install, and clean it up and make it look pretty, as well as grab a two wheel peel internal for it. 2.72s IIRC.
It felt appropriate to pick up the rear for the Camaro, in the Camaro.
#1104
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Would any of you guys happen to have a 86-88 350 prom? I know it's a long shot.
#1108
1 Post
Gonna take the rear spring isolators out to level it out. I likey. Drives better too. Don't have to drive it like its lowered either
#1109
1 Post
No isolators in the rear. Hopefully it'll settle just a little more. Took it on a 10 mile drive.
I dont know why the ibautogroup app keeps turning my pics. They are perfectly fine in my gallery on the phone.
#1111
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Looks really good. Are you going to keep that top mount intercooler and the scoop, or will you go with a front mount eventually?
#1116
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Do any of you guys want some free parts for thirdgens? I have a big box of stuff and they're in OK condition, but I really dobt anybody would buy them. Ask for something, and I'll see if I have it and if I do, you guys can have it for free.
#1117
Car: 1987 Trans am
What ya got? Only need a ECM at the moment, waiting to hear back from Rubber on that.
#1119
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
A little bit of everything. I sold my speed parts, but I have a coolant overflow tank, windshield wiper washer tank, torque arm, torque arm mount, SBC motor mounts, gauge cluster, 1984 Z28 ECM, cruise control module, gray carpeted center console, gray cargo area carpet, hatch pulldown motor plastic, rear seatbelts, rear seats, and there's more stuff I'm forgetting about
#1120
#1127
If he doesn't make the drive to pick up the rear seat belts, I'll take them. Do they work? Meaning, do they still lock when pulled out all the way and then released, or even tug hard on them and they lock? Mine do neither and are always loose. Need them to strap my daughters car seat back there.
#1128
#1130
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
#1131
Car: 1987 Trans am
I had a full set of belts but threw them out recently. Didn't think anyone would want them.
#1133
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
I'll probably do the same if no one claims the crap I have. In other news, I got my floor pans finally welded in. Just need to clean the welds up and use some bondo on the seams to make it look purdy.
#1135
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Intrax lowering springs. I might have the paperwork from when I bought them. might be able to find part numbers. They were a good set. nice even stance. if you have a real low exhaust of deep trans pan, or a wife that hits things. They might not be for you.
#1136
1 Post
I was hoping the back would drop just a hair more, but it seems they have completely settled now. I am tempted to put the spacers back on just to see. I did however order the Founders on car adjustable PH bar. Only $72 too, made the choice easy. I think after I get all the exhaust stuff and the front mount intercooler squared away my next order will be subframe connectors. Getting some OT this week and next at work and I'm now a manager so it'll give me some money to burn lol.
#1137
Will you be going with the the poly or rod end phb? I have rod/rod on mine. Same with the LCA.
#1138
1 Post
So what height did that put you at? I removed the isolators on my rear and put hose back there. Dropped the rear another 1/2". Will get pictures once I get a new ball joint, rod end, end links, and alignment done.
#1139
1 Post
Hey Jim, the springs put me at 26 1/4 front and 26 3/4 in the rear. Isolators in the front and nothing in the back.
#1140
1 Post
#1142
1 Post
Jim, I think you would use like 1/2" heater hose for the back springs if you ditched the isolators. These Intrax springs so far don't make any noise yet without anything on the back springs.
#1143
Car: 90RS Conv.
Transmission: th400
i believe I still have a working tank and motor. the tank has a bulkhead fitting on the bottom of it for my meth kit. I don't use it, since I put the tank in the trunk. its in a box, in the attic......
anyone have the passenger side black plastic for iroc style taillights? I put the battery back up to the front, so I don't need the cutoff switch back there.
#1144
I wonder how much I would have to lob off the back springs to get that extra 1/2" drop back there...... I have nothing on the back, no isolator or even hose.
#1145
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
So, when do you guys wanna do another meet?
As long as I don't break anything (knocks on wood with a rabbit foot) I would like to hang out.
#1146
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Me included, I'll probably be free for a meet in a month or so once I'm done with this semester. How about may 15th or 16th? I don't care about the location, I can drive wherever.
#1147
1 Post
HOLY HELL! Trans is done and in and WOW! What a difference! Beyond my wildest expectations having never even disassembled an auto trans before!
No shift delay whatsoever and pulls so good at only 7psi. Way quicker than before with the bastard trans slipping. I beat the brakes off that thing, look at all the clutch material, LOL.
I'm down. Probably have an improptu meetup fairly soon being the rebuilt trans is in and working.
#1148
1 Post
Anyone got one of those nose filler panels for sale?
#1149
1 Post
Impromptu meet Saturday? I'm off that day, anyone down?
Need to know who to try to set it at a central location.
#1150
Car: 90RS Conv.
Transmission: th400
made a test run today, and all good. I need to re-lash the valves. and make another run.
next weekend is the Good Guys car show in Kiss. at the Silver spurs arena.
