Official Tampa, FL Area Thread
#951
Re: Official Tampa, FL Area Thread
i was having similar charging issues a few years back. on a friends suggestion, i added a 10 gauge wire from the alt to the battery +. never had another problem, even after putting the battery in the back. strange huh?
#952
simple voltage drop test;
http://forums.hotrod.com/circle-trac...your-race-car/
less than 3 minutes and your done. very easy to do and well worth it.
#953
I've got a new wiper motor on order, and I've been browsing better plug wires, any suggestions?
Loneroad, if you want a hand this weekend let me know, I'm just putting my power steering back on this weekend.
#955
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
I should be ok. I got 12volts before the relay but 10 and dropping to the fuel pump. I ordered a new fuel pump relay kit. Im hoping that when I put the interior in I pinched a wire in the carpet or sill plates. either way its coming out and being replaced. Im probably going to change location of the realy too. I had it under the carpet where the rear seat used to be,right above the sending unit wires. in case I had to leave the car somewhere I could reach back and pull the relay.
The battery is in the trunk, im not sure exactly where im going to put it at this point.
#956
Are you running one of those Holley electric carb fuel pumps?
#958
looks like some decent wires to me. i've used accel wires a few times with no complaint.
i like the custom fit wires. usually comes out cleaner.
years ago i always used solid core wires. but the last MSD box i bought says not to use solid core wires. never noticed that before.
ive been using the summit or jegs house brand wires the last few times. no complaint there either.
read a lil tip about cleaning the outside of plug wires. (im lazy now and dont care), but, if you use a rag and vasoline, they clean up pretty easy.
helped a buddy put some DOHC motor in his civic yesterday. had a great time smack-talking all day.
#959
#960
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
Was browsing craigslist because I was bored and saw this car listed
http://orlando.craigslist.org/cto/4843555000.html
I knew that car was a member's on here and I found it to be built91z28's car. I loved that car when looking through his build threads awhile ago and it's sad to see it's in that condition now. He hasn't been on in two years, so it's probably been sitting outside for awhile...
#961
#963
i've had those cheap wire looms before and didnt care for them. but you might have better luck?
the boot gaurds seem like a good idea. i've considered using them a few times, but havent burnt a boot yet.
the craigslist camaro seems to have a very nice drivetrain, but i agree, never gonna get that much money.
pretty paint and wheels sell cars. most people wouldnt understand the motorhead lingo, or care. its sad, but true. does sound like a nice car to me though, lol.
#964
Installing new plugs tonight, I've got noise near that rocker that was loose again. Just needs to last till I can get a new daily.
I also ordered the sending units for my oil pressure, and water temp gauges. Hopefully can have those working this weekend.
#965
man, sorry to hear about the rocker noise again. it can only be so many things. so frustrating sometimes. i went through a bad batch of pushrods about 5 years ago. kept breaking em up by the tip. finally changed them all out and never had a problem again. not saying thats your issue. a mechanics stethascope might help isolate the noise. theyre cheap at harbor freight. like under $5. very handy tool to have.
if its a fresh build, re-tighten header bolts. well,...i know your not a rookie.
i've done nothing but add air to a low/leaky tire all week. yup, a slacker.
#966
Haha, I need to recheck header bolts. I was supposed to fix it this weekend and put the power steering on. But I was too lazy and didn't.
If anything, this rocker is an excuse for better heads, intake, and carb.
I readjusted my seating position last week and its so much better now, really needs a manual to be even more fun. Lol.
Ordered a new wiper motor and seal. That makes $300 spent on the car today alone. I'll have a $250,000 car soon enough. Lol.
Also, Loneroad. How much did you want for that B&M oil cooler? I'm going to be putting together an oil system soon to replace this junk canister filter.
#967
1 Post
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
#968
1 Post
I work straight through to at least saturday, and wont find out my next days off till saturday as well. Ill let you know then if ill come out this weekend.
#969
Car: 90RS Conv.
Transmission: th400
the b&m plate style is on my car. i have a new hayden tube and fin style trans cooler i can get rid of.
willie, id dint get to the springs this weekend. Ill try to get them yanked this weekend coming up.
#971
1 Post
Thats alright man, I'm not sure if I can get out there this weekend or not either. Good news is I'm about to order all I need to rebuild my trans tonight.
#972
good luck on the tranny rebuild. any hi-po parts going in or basic rebuild? i gotta admitt i was never far in a tranny til i tore my th350 apart. it wasnt as bad as i thought it was gonna be. its working great so far. i think im going to treat her to a new filter and fluid just to get any possible rebuild dirt/junk out of there. probably a smart idea?
about time for new plugs here too. usually once a year i change them, and at 6 months i clean & spark test them. i dont index, but even spark check new plugs. hey, guys can drop them at the parts store,...you never know. i make one of my boys pull the mower cord while i use a welding glove, lol.
last time i bought plugs it was for my sons truck, a 350. the azzholes put 2 different heat range plugs in the 8-pack box. luckily i noticed it. that was a new trick to me.
#973
#974
1 Post
Yea, last time I got plugs, Advance gave me 2 different kinds. Now when someone buys plugs at Autozone I double check part numbers and the gap for the customers.
After the rebuild I will finally feel the real difference with the turbo, compared to the beaten, battered and slipping trans that in here now. Though I can't complain, slipping or not it hasn't let me down or left me stranded. Thanks to Ducky I have been able to drive my car after nuking the 3-4 pack in the trans I am about to rebuild, lol.
This will be my first trans rebuild, though I have already disassembled the 700 to familiarize myself with the internals. It shouldn't be too bad and Ill take my time with it.
#975
i watched a bunch of videos on youtube first, lol. gotta love todays information highway.
the first time i put it back together i broke a small ring. long story short it was my fault for building it sideways on the workbench. it was pointed out to me that it must be built standing up. some parts stack and are only held in place by gravity. hey, it was my first one, lol.
i guess theres a certain sense of pride in rebuilding your own tranny, like building a motor? sure saved a boat load of money too!
#976
#977
i could use some ideas. my fiberglass cowl hood is cut out in the back, homemade airpan, works great. But, when it rains i get water splashed in there sometimes. so i've been throwing a towel in there now and then. it helps some. but i'd like to find a plug similar to this;
http://www.summitracing.com/parts/hrd-1999/overview/
it needs to be about 3" x 25" overall. i wonder if anybody makes one or i could make something? i thought about cutting up an old couch cushion but IDK? any suggestions on some better foam? maybe cut it out with a hot knife so it doesnt fall apart?
#978
Car: 90RS Conv.
Transmission: th400
i suppose im not real tech savvy? hey, im a grandpa 3 times already.
are you looking to make it removable or permanent? or just somethuing for when it sits?
I would think that anything removeable would get sucked out at speed.
#979
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
#980
i want it removable. its just for when it sits outside. i have a carport, but often times i have other projects under it and the iroc must be in the elements.
i hadnt thought of a craft store. thats a good idea.
#982
I've been having a burning oil smell the last two days, went searching for it tonight, seems I have a leaky valve cover gasket. Not a big deal, I'll replace both Saturday. Napa sells them for the same price as AZ, going to get them from there. Also will have my alt tested at AZ, if they tell me its bad I'm going to get my money back and go buy one from Napa.
#983
1 Post
#984
Car: 90RS Conv.
Transmission: th400
look into something like these with studs. a little blue locktite on the studs and you never have to worry about the gasket slipping while putting the v/c back on
http://www.summitracing.com/parts/pro-302-315/overview/
#985
if you want to make things easier on yourself, dony buy the cork gaskets . buy the rubber and steel gaskets. they are reusable and last forever. more importantly they don't squish and leak,
#986
those rubber gaskets work great. i'm done with cork.
we used to use a/c condensors for tranny coolers. they work awesome!
cold enough for everybody?
#988
1 Post
Car: 1985 Z28
Engine: Turbo 5.3
Transmission: 4l80e
Axle/Gears: Ford 9"
And the cold is great, finally feels like there's another season here, lol.
#991
This cold reminds me of the mornings in Germany walking to school(well, not quite as cold but just a reminder)....if there were 30-50mph winds to go with it, it would remind me of El Paso, TX and waiting on my school bus to come late as usual. It was miserable at the time, but still, I LOVE IT!!!
#992
Ended up leaving at 12. Got over 15 hours in yesterday.
Yeah, I'm loving this weather too!
#993
Car: 90RS Conv.
Transmission: th400
well, im at a crossroads. i had to drive up to north Orlando to buy 5 gals of ms 109 and get my bottle filled. the place i used to go to has closed.
I looked into getting my own mother bottle and pump to refill my own bottles but, that's gonna run around 1500 to get myself setup. and i would still have to drive up to exchange bottles. i asked, you can get about 4 refills from amother bottle.
the expense would be ongoing....Im thinking about going to the dark side..turbo
i bought all the turbo books, iguess its time to sit down and read. At least the car is up and running, and i can play with it while i build the turbo motor.
#994
1 Post
You'll never go back, lol
#995
Car: 90RS Conv.
Transmission: th400
yeah, Im going to fast xfi this year, so I guess its the next transition..
with forced induction where does head runner size come into play?
I have the AFR 1095's. comp port 195"s on a 383.
im looking at going with the dart lil m. the 195s would be a little on the small size NA for say a 421-427. but are they small for forced. what is the rule of thumb on picking runner sizes?
#996
Installed the new plugs and wires today. Car runs better than it did before the misfire came back. I'm really happy with it now.
#997
1 Post
Good to hear. I had a feeling it was that nasty plug from before the valve lash was done.
#998
1 Post
The above is what I gather from forced induction, but may differ some from my assumtions. I would think torque down low to help streetability/spool time would be best, cause the turbo would take over once in boost.
#1000
Car: 90RS Conv.
Transmission: th400
just found this on the bullet
http://www.thetruthaboutcars.com/201.../#more-1008890
RD this looks up your alley
